Oil pressure and oil temp gauges, where on engine?
where on my ea82 mpfi do i put the aftermarket sensors for oil pressure and temp, both mechanical?
There should be an unused bung on the front of the oil pump
This is an oil pump from an EA82 with a oil pressure gauge and an oil pressure switch
If you dont have a factory oil pressure gauge, you will only have the small sensor (that is directly right of the filter) and there will be a bung in the place of the large cylindrical sensor. I also recall there may be a bung on the underside of the pump as well.
All you need is the right sized adapter for your gauges
Thread tape will be fine, as long as you use stuff that is suitable for oil and petrol. I think it may be pink?
- littlewhiteute
It doesn't matter, the thread still makes contact.spambo wrote:if your using an aftermarket electrical guage don't use too much thread tape as the guage usually earths through the block and the tape can sometimes stop this meaning guage no worky,
Old wives tale.
NPT or BSP threads are a taper.
Gary
Gary
- Mr Top Hat
The factory oil pressure light is beside the alternator on top of the block.Mr Top Hat wrote:sorry to highjack thread but what about putting oil temp and pressure sensors on a Ej22 first gen does anyone know?
Here is a t piece with an oil pressure gauge sender and oil pressure switch
Hey Gannon,
Did that pressure sending unit clear the bracket for the power steering pump or did they have to twist it around some more?
This is how I've done it (mechanical setup): Got the hot coolant (engine out, heater in), added a plumbing T piece with some barbed/spurred nozzles to fit it in the line.
^ Temp unit doesn't work anymore, I presume the cold of the snow, plus freezing my coolant last year killed it in the end...
^ Slots very nicely between everything around it
That motor was going into a VW so power steering wasn't needed.
