ej18 into MY wiring harness woes
I think we cut one too many wires when stripping the harness. The end result is an ECU which seems to not be powering up, and therefore isn't running the fuel pump or anything.
Has anyone got a soft copy of the appropriate wiring diagram, or off hand know if there is a constant power wire going to the ECU?
I've got a wire going to the ignition circuit, and a big thick yellow wire going straight onto the +ve battery from the ignition relay, but I think the ECU needs some sort of power to it to actually be able to trip the ig. relay.
Also does anyone know of a way to test that the ECU is powering up? doesn't seem to be any lights inside it.
Symptoms:
1) Ignition relay not clicking when turn key to 'on'
2) EFI ( VL ) Fuel pump not getting power from ECU
I've got a thick yellow wire from the Ig relay to +ve through a 20A fuse. Test light shows power to at least this point.
I've got a wire going to Ignition power, Test light shows this gets power. Traced to wire into ECU and test light lights up there too.
I've got another wire going to the Starter +ve. ( can't remember if I tested that, will test tonight ).
The engine plugs are all plugged in, the Oil temp isn't, but the 02 sensor is.
I'm told this should be enough to start the engine, but it doesn't.
Any ideas ?
Any ideas ?
- Fury
Sending pm with details you need ( 95%sure anyway)
Chris
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT!
Fury came through with the win!
There was another wire ( Yellow with black stripe ) that needed to go into the Ignition circuit. Now I get the Ig and Fuel relays click ( fuel clicks probably twice a second, but I think it's supposed to do that? ) The EFI pump turns on.
I need to get some better clamps and fuel hose as there's a couple of leaks at the joins, so I haven't tried to turn the engine over too much yet.
I'll get better hoses/clamps tomorrow and see if I can get her started.
It's getting close!
It's getting close!
- Outback bloke
- Fury
Brett, If you want, I can do some of those as a quick reference, as far as pinouts , schematics and voltages and fault codes for ecu's - so they can be posted as downloads. Paul's was just a roughy, as I couldnt copy the files - had to scan hard coppies etc.
I have several models available ( not just Subies), so if you want...i can do a few that are popular, or send you the disk ( its only a demo for 14 days - installed yesterday) Cant say what it is, as it is heavily copywriten - and used by mechanical workshops.
I can PM you with details. I know you have the FSM's up there, but these are a simple reference..
I'm pleased that it was a help Paul
Chris
Chris
Chris
SUBARU IMPREZA 1.6L & 1.8L (EJ16 & EJ18 Engines) 1993 - 96 Engine Management Systems
Go To: INDEX Go To: COMPONENT LOCATION Copyright Ó Repco AUTO-TECH
Wiring Diagram
See Key to Wiring Diagram.
101 Battery 130 Air Conditioner Pressure Switch
102 Fuse SBF2 131 Air Conditioner Switch
103 Fuse SBF4 132 A/C Thermal Protector Switch
104 Ignition Switch 133 Air Conditioner Compressor
105 Fuse #16 134 A/C Evaporation Thermo Switch
106 Fuse #15 135 Diode
107 Inhibitor Switch (Auto) 136 Idle Air Control Valve
108 Fuse SBF5 137 Canister Purge Solenoid
109 Fuse #13 138 A/C Idle Up VSV Solenoid
110 Starter Motor 139 Relay - Main
111 Transmission Neutral Switch (Manual) 140 Relay - Fuel Pump
112 Instrument Cluster 141 Fuel Pump
113 Tachometer 142 Fuel Injectors
114 Malfunction Indicator Lamp 143 Oxygen Sensor - Heated
115 Vehicle Speed Sensor #2 144 Engine Coolant Temp. Sensor
116 Relay - Main Cooling Fan 145 Mass Air Flow Sensor
117 Main Cooling Fan Motor 146 Igniter
118 Sub Cooling Fan Motor 147 Ignition Coil
119 Diode 148 CO Resistor
120 Twin Diode 149 Throttle Position Sensor
121 Air Conditioning Relay Holder 150 Crank Angle Sensor
122 Fuse 20 Amp 151 Automatic Transmission ECM
123 Fuse 10 Amp (Automatic Vehicles Only)
124 Relay - Main Cooling Fan #2 152 Power Steering Pressure Switch
125 Relay - Sub Fan #1 153 Read Memory Connector
126 Relay - Sub Fan #2 154 Check Connector
127 Relay - Air Conditioner 155 Data Link Connector
128 Relay - Air Conditioner Cut Out 156 Test Mode Connector
129 Air Conditioner / Heater Fan Switch 157 Engine Management ECM
also this: http://lib.store.yahoo.net/lib/mroseusa/93ej18.gif
but colours seem to be a bit different.
and
ECM
The ECM is located under the Left Hand Side of the Dashboard.
It controls the EFI System and Ignition.
It also has a Fail Safe back up System.
ECM Voltage Table
Connector ‘A’
1 through13 top row
14 through 26 bottom row, when looking AT the PLUG clip at top
Pin # Circuit and Status......................................... Voltage
A1 Air Flow Sensor Ground
All Times........................................................ 0 Volts
A2 Idle Speed Controller
Engine Idling................................................... Voltage Pulses
A3 Engine RPM Output
A4 Vehicle Speed Sensor
Ignition ON..................................................... 0 or 5 Volts
Front Wheels Turning...................................... 0 to 5 Volts Fluctuations
A5 Serial Data - Subaru Monitor
No Specifications Available.............................. N/A
A6 Serial Data - Subaru Monitor
A7 Radiator Main Fan Relay #2 and Sub Fan Relay #2
Ignition ON
Relays Energized............................................ 0 Volts
Relays Not Energized...................................... Battery Volts
A8 Fuel Pump Relay
Ignition ON..................................................... 0 to 10 Volts Fluctuating
A9 Air Conditioning Cut Out Relay
Ignition ON
Relay Energized.............................................. 0 Volts
Relay Not Energized........................................ Battery Volts
A10 Power Supply
Ignition ON..................................................... Battery Volts
A11 Air Conditioning Switch
Ignition ON,
A/C Switch ON............................................... Battery Volts
A/C Switch OFF.............................................. 0 Volts
A12 Starter Switch
Engine Cranking.............................................. Battery Volts
A13 Power Supply
A14 System Ground
A15 System Ground
A16 Neutral Switch Manual Trans
Ignition ON
Transmission In Neutral................................... Battery Volts
Transmission In Gear....................................... 0 Volts
A17 Transmission Identification
Ignition ON
Automatic Transmission Fitted......................... 5 Volts
Manual Transmission Fitted............................. 0 Volts
A18 Self Cut-out
A19 Read Memory Connector
Ignition ON
Connected...................................................... 0 Volts
Disconnected.................................................. 5 Volts
A20 Test Mode Connector
Ignition ON
A22 Malfunction Indicator Lamp
Ignition ON
Light ON......................................................... <1 Volts
Light OFF....................................................... Battery Volts
A23 Radiator Main Fan Relay #1 and Sub Fan Relay #1
Ignition ON
A24 Air Cond. Load Signal Fast Idle Control
Engine Idling
Air Cond. ON.................................................. Battery Volts
Air Cond. OFF................................................ 0 Volts
A25 System Ground
A26 Power Supply
Connector ‘B’
1 through 22, when looking AT the PLUG clip at top
Pin # Circuit and Status.......................................... Voltage
B1 Fuel Injector #2
Ignition ON...................................................... >10 Volts
B2 Fuel Injector #1
B3 Engine Coolant Temp Sensor
Engine Warm/Idling.......................................... 0.7 to 1.0 Volts
B4 Throttle Position Sensor Signal
Ignition ON
Throttle Fully Open.......................................... 4.5 Volts
Throttle Fully Closed........................................ 1.0 Volts
B5 Air Flow Meter Signal
Ignition ON...................................................... 0 to 0.3 Volts
Engine Idling................................................... 0.8 to 1.2 Volts
B6 Crank Angle Sensor Reference Signal
Ignition ON...................................................... 0 Volts
Engine Idling................................................... ±6 Volts AC
B7 Crank Angle Sensor Ground
B10 Oxygen Sensor Signal
Engine Idling................................................... 0 to 0.7 Volts Fluctuating
B11 System Ground
B12 Fuel Injector #4
B13 Fuel Injector #3
B14 Power Steering Switch
Ignition ON
Steering Wheel Turned - Switch ON.................. 0 Volts
Steering Wheel at Rest - Switch OFF (no load).. 5 Volts
B15 Throttle Position Sensor Power
Ignition ON...................................................... 5 Volts
B17 CO Adjustment Signal
Coolant Temp 80°C
Vehicle driven for 1 Minute @ 24 kph
Engine speed to above 2,000 RPM, Idle Engine
Ignition OFF.................................................... 0 Volts
Ignition ON...................................................... 12 Volts For 1 Minute
B19 Purge Control Solenoid
Ignition ON
Solenoid Energized.......................................... 0 Volts
Solenoid Not Energized.................................... Battery Volts
B20 Ignition Control Cylinders 3 & 4
Engine Idling................................................... <3.4 Volts
B21 Ignition Control Cylinders 1 & 2
Ignition ON..................................................... 0 Volts
B22 System Ground
ECM
ECM Voltage Table
Connector ‘A’
1 through13 top row
Ignition ON
A8 Fuel Pump Relay
Ignition ON
A10 Power Supply
Ignition ON,
A12 Starter Switch
A13 Power Supply
A14 System Ground
A15 System Ground
Ignition ON
Ignition ON
A18 Self Cut-out
Ignition ON
Ignition ON
Ignition ON
Ignition ON
Engine Idling
A25 System Ground
A26 Power Supply
Connector ‘B’
B1 Fuel Injector #2
B2 Fuel Injector #1
Ignition ON
B11 System Ground
Ignition ON
Coolant Temp 80°C
Ignition ON
B22 System Ground
- BaronVonChickenPants
Fury and stinky you're legends, thats heaps easier to understand than the FSM pages I've got, I'm greatful to have them but they take some serious thinking to figure out.
So now for the real question, have you started it yet
Jordan.
Jordan.
