Defected for Sunnys
Lenigas
Defected for Sunnys
Post by Lenigas » Fri Jan 07, 2011 3:48 pm
Hi guys, just a heads up, I got defected for having sunnys on my Lseries. I didn't think cops would care but their track is too wide apparently. Just thought id post it so you know what to possibly expect.
Post by guyph_01 » Fri Jan 07, 2011 4:07 pm
what do you mean? sunnys as in window tint?
littlewhiteute
Post by littlewhiteute » Fri Jan 07, 2011 5:19 pm
He means Sunraysia rims. Or Coyotes, typically wrong offset causes track increase and rubbing on guards.
Same as my avatar, but I have Scorpions now.
Gary ;)
Pav
Post by Pav » Fri Jan 07, 2011 7:31 pm
Were they sticking outside the guards? I got defected because of that on my old subi...
Post by Gannon » Fri Jan 07, 2011 7:47 pm
Usually on a MY they are fine, because their track is slightly narrower.
But on an L the track makes Desert Rats, Sunrasias, Coyotes etc. wider than the wheel arches.
Go to Clark Rubber and get some rubber arch flare and screw to the underside of your mudguards
Post by Silverbullet » Fri Jan 07, 2011 10:29 pm
Could anyone tell me what wheels these are? sorry I don't have a closeup, since I don't know what they're called I couldn't google it :D Anyway Dad has these wheels on his L series at the moment (here in SA) and they stick ever so slightly outside the stock wheel arches. I can always tell because it looks a bit cooler than all the other L's :rolleyes:
But they don't rub and he's never had a problem with cops or when he gets his tyres changed they don't say anything...
FujiFan
Post by FujiFan » Fri Jan 07, 2011 10:37 pm
Yep the old Performance mags on my L wagon (Same as old Pug 505 wheels) stick out past the body line like the proverbeal. When I got the RWC last month the Mechanic made mention of it, as I expected. So far no hassle from the fuzz bout it..
Post by sven '2' » Fri Jan 07, 2011 10:55 pm
Lenigas wrote:Hi guys, just a heads up, I got defected for having sunnys on my Lseries. I didn't think cops would care but their track is too wide apparently. Just thought id post it so you know what to possibly expect.
What were you doing at the time the Police stopped you?
Post by guyph_01 » Sat Jan 08, 2011 12:19 am
Ohhhhh, true didn't think of that.
Yeah my bro's brumby got stickerd for the same thing:( and now since its got a 4inch kit we are going down to 2inch to be able to pass the pits. :(
Post by El_Freddo » Sat Jan 08, 2011 8:54 pm
guyph_01 wrote:Ohhhhh, true didn't think of that.
Go the 4 inch and see what happens :twisted:
As for the sunny's - I doubt they're the standard rim as they do not protrude outside the guard, unlike desert rats or speedies, I'm not sure which one I'm running with the 27's but they stick out almost an inch up front and half an inch at the rear.
I'm just not keen on drilling holes in my guards to put flares on, but will look into the type of flares that screw in from under the flare rather than through the side (which is where I have the issue).
So what where you doing? Cops look at me, the local one here at lakes almost snapped his neck the first time he saw it - and that was with stock tyre diametre but a three inch lift...
Post by steptoe » Sat Jan 08, 2011 9:23 pm
I may be slow Bennie, but looks like you have moved - teaching?
It is that time of year for defects and everything else safety related -starts with school formals with the hotties turning up with the kiddies onboard.
sublime
Post by sublime » Sun Jan 09, 2011 3:06 am
Silverbullet wrote:Could anyone tell me what wheels these are? sorry I don't have a closeup, since I don't know what they're called I couldn't google it :D Anyway Dad has these wheels on his L series at the moment (here in SA) and they stick ever so slightly outside the stock wheel arches. I can always tell because it looks a bit cooler than all the other L's :rolleyes:
Silverbullet you probably should have started another thread with this question, however the wheels are made by Performance. Sorry I do not know the 'name' of the style but if you look closely at the painted black area where the wheel nuts go you will see 'Performance Wheels', or something like that.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
d_generate
Post by d_generate » Sun Jan 09, 2011 3:16 am
I had very similar mags on my RS2000 Escort about 25yrs ago, I think they would still look good to this day.
Post by Silverbullet » Sun Jan 09, 2011 9:49 am
sublime wrote:Silverbullet you probably should have started another thread with this question, however the wheels are made by Performance. Sorry I do not know the 'name' of the style but if you look closely at the painted black area where the wheel nuts go you will see 'Performance Wheels', or something like that.
Oh ok thanks! just thought I'd mention it here because these wheels are a bit wide on the L and I didn't have a better pic.
Post by El_Freddo » Tue Jan 11, 2011 12:35 pm
steptoe wrote:I may be slow Bennie, but looks like you have moved - teaching?
No, I've become the no1 toilet cleaner in Lakes :D :D YAY! Seriously though we're working jobs to get us through to next snow season - cleaning, waitering, maintenance man and underwater ceramic detailing technician. Keeps us busy when the tourists are around. Unfortunately they've gone back to work and we've hence lost lots of work :( :(
End Hijack.
Think I'll be looking into some flares :???: not keen on them!
sublime
Post by sublime » Tue Jan 11, 2011 7:13 pm
Silverbullet wrote:Oh ok thanks! just thought I'd mention it here because these wheels are a bit wide on the L and I didn't have a better pic.
Early Subarus had wheels with an offset more like a RWD wheel. With the L Series in '84 the offset was like a FWD rim.
My 1978 Wagon has Peugeot 505 15 inch rims and they fit within the guards perfectly. On an MY they would 'just' fit at the front and on a L they would stick out past the guards.
Gotta say I love the photo you posted! The side stripe suits the wheels to a 'T'.
Old Boxer Tricks
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
Phizinza
Post by Phizinza » Tue Jan 11, 2011 8:33 pm
I knew it was only a matter of time before this would happen. Always known Speedy Desert Rat 14" wheels are illegal...
Lenigas
Post by Lenigas » Wed Jan 12, 2011 12:16 pm
sven '2' wrote:What were you doing at the time the Police stopped you?
Driving home from the south coast back to Adelaide, to make it worse I just had a defect removed 30mins before at victa for spotties mounted on the roof, hehe. Cop was standing on the side of the road looking at cars and pulled me because of the over sized track. According to the cop even rubber flares wouldn't make it roadworthy as they stick out from the original chassis. Seems to be heaps of inconstancy in the rules, really unfair but what can ya do?
sublime
Post by sublime » Wed Jan 12, 2011 3:21 pm
Lenigas wrote:Driving home from the south coast back to Adelaide, to make it worse I just had a defect removed 30mins before at victa for spotties mounted on the roof, hehe. Cop was standing on the side of the road looking at cars and pulled me because of the over sized track. According to the cop even rubber flares wouldn't make it roadworthy as they stick out from the original chassis. Seems to be heaps of inconstancy in the rules, really unfair but what can ya do?
I do not think there is really any inconsistency, you are simply not allowed to increase the track by more than 25mm. This of course makes Desert Rats and similar wheels illegal. Having said that some people do get by with adding flares...
Old Boxer Tricks
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
Return to “South Australia”
