ebay thermo fans
hazzard
ebay thermo fans
Post by hazzard » Mon Dec 27, 2010 9:03 am
I was looking on ebay at thermo fans and it looks like theres some pretty good thermo fans for a pretty decent price was just wondering if anyone has got aftermarket thermo's and how much cooler do they make your engine run
Post by TOONGA » Mon Dec 27, 2010 9:38 am
It depends on the fans and how much air they claim to push or pull. I have an after market fan on my radiator as there is no room for the originals and it works fine, sorry no Idea of the brand.
yarney
Post by yarney » Mon Dec 27, 2010 12:13 pm
With aftermarket fans you can get different sizes and they supposed to be better than stock depending on the type
A fan will only make the engine as cool as the thermostat will let it get it's when the engine is under load that it will make a difference
Jan
hazzard
Post by hazzard » Mon Dec 27, 2010 1:17 pm
Ok cool well do you know what size id need for a 92 model brumby cause theres a 10 inch wich pulls 1340 cfm i think it said
yarney
Post by yarney » Mon Dec 27, 2010 3:03 pm
You will have to measure the radiator top to bottom and the distance from the radiator to the engine to make sure that they fit.
Jan
hazzard
Post by hazzard » Mon Dec 27, 2010 3:29 pm
They will definatly be thin enough there slim line ones only 35mm wide at the widest part so thats all good just gotta wait for this rain to bugger off so i can start playin with it all
d_generate
Post by d_generate » Mon Dec 27, 2010 6:18 pm
I'm seriously thinking of putting one under my bonnet scoop to blow through the top mount and possibly get rid of some turbo heat also when I'm slugging through the soft stuff, I should have enough room since I put the 30mm Outback spacers in the front X member.
yarney
Post by yarney » Mon Dec 27, 2010 6:29 pm
d_generate wrote:I'm seriously thinking of putting one under my bonnet scoop to blow through the top mount and possibly get rid of some turbo heat also when I'm slugging through the soft stuff, I should have enough room since I put the 30mm Outback spacers in the front X member.
I wonder how that would go myself keep us informed
Jan
d_generate
Post by d_generate » Tue Dec 28, 2010 2:46 am
Apparently it's a popular mod on the turbo's on the bigger Nissan etc 4X4 forums with cars getting a heap more hp because of the cooler inlet temps.
