Your Christmas wish list- Subaru based
Hazey
Post by Hazey » Sun Dec 05, 2010 3:03 am
Time for a little fun and get into the spirit of the season. Who knows, maybe the jolly fellow in the red suit might stumble upon this site for some ideas :D
Some simple guidelines- List three products you would like to find under your Christmas tree for your Subaru. No pie-in-the-sky items or things you can only dream to exist... Basically any product you can actually get a hold of in the foreseeable future, new or second hand.
I'll get the ball rolling with my top three, in no particular order:
-SubaXtreme Brumby bullbar
-Rigid Industries 20" LED light bar
-A nice sized Waeco or Engel fridge.
Your turn :)
Post by TOONGA » Sun Dec 05, 2010 8:57 am
hmmmmm the dual range setup Ive been looking at down my way and a scorpion low range gearing to go in it
I may have to put a deposit on all the bits and hope santa can pay the rest for me
subybrumby
Post by subybrumby » Sun Dec 05, 2010 9:01 am
1. A decent tune on an EA82T fitted with an EMS stinger ECU done here in Toowoomba
(That will happen I expect)
2. A decent drink holder that I can permanently fit in the cab that looks like it was custom made for the Brumby ute and not some cheap ass junk that fits on to an air vent.
3. A long range stainless fuel tank fitted underneath for a planned trip to Darwin next year. Sheet metal worker son to look at that. Got more wishes if you want to expaaannnd the number.
Venom
Post by Venom » Sun Dec 05, 2010 11:00 am
Have you had a look at the Gen2 Liberty pop out cup holder? It is DIN width, very slim and will take your can of coke/cup of coffee. 600ml bottles don't fit though...
Onto my wishlist:
1. My liscence back...
2. Gen1 dual range lib gearbox. Then i can think about building a magical centre locking, 4.44 ratio, 1.59 low range gearbox.
Dann
Post by Dann » Sun Dec 05, 2010 12:15 pm
hey guys i thought i might just pop mine in :P
1. EJ22
2. LSD diff locker
3. kings springs, or something similar
i know i'm abit behind you guys but hey i'm getting there :P
Dann
Looking for:
- LSD diff
Post by Silverbullet » Sun Dec 05, 2010 12:30 pm
1. MIG welder (for the body work hehe)
2. Weber carb
3. 2" lift kit
All dreams I'm afraid :rolleyes:
d_generate
Post by d_generate » Sun Dec 05, 2010 3:30 pm
More than 8.5psi boost, hope the new V2 RA STI ECU will help.
1 more inch of lift.....coming soon
spike
Post by spike » Sun Dec 05, 2010 4:28 pm
the 2 door rx i saw..........
so cheap, duel rage awd locking box, EA 82T factory intercooled
=D*****
but again i doubt ill get it, just want all my parts to come and to fix my honda so i can start building lisa
Post by Gannon » Sun Dec 05, 2010 8:51 pm
1. New shocks and raised springs to go on the Outback.
2. Finish the RX
Post by steptoe » Sun Dec 05, 2010 10:13 pm
1. time - to finish what I have started
2. motorvation - to get underway
3. reliability of finished projects ~ EA82T heads and gaskets please
Johnny T
Post by Johnny T » Sun Dec 05, 2010 10:45 pm
my list is:
1: New Fuel pump
2: The car to start
3: New / used suspension to fix that air leak
Johnny T
88kw of fun waiting to happen
Post by El_Freddo » Wed Dec 08, 2010 6:25 pm
1) SC14 supercharger
2) crossbred conversion kit x2
3)engineer's certificate for 27 inch tyres, 3 inch lift and EJ22 with super charger :D
Post by guyph_01 » Wed Dec 08, 2010 6:36 pm
Here is mine:D
-EJ25 single cam.....(Found A QUAD cam EJ25, soon to be mine:p)
-RXII Full Time 5spd D/R with diff lock Gearbox
-CLSD Diff (if I can find one)
-5stud conversion
-Forester rims (bought a set:p)
-All new bushes (front half already installed:p)
-New Front and rear suspension
-Replace heater core
-Better dual rear wheel carrier
Post by Subafury » Wed Dec 08, 2010 9:26 pm
-a 5sp that doesnt whine like a little bitch/6 speed box
-some gold rims n tyres
-apexi power fc
-sti wing.
only the tyres are likely tho hahah
78sti
Post by 78sti » Thu Dec 09, 2010 10:09 am
Coilovers
Semi slick tyres and 16" mags
Pipe bender
Tonneau cover or better Still Ute lid
Post by El_Freddo » Thu Dec 09, 2010 7:45 pm
Venom wrote: 1. My liscence back...
That's gotta suck mate - if you had've lost it in June you'd probably have it back for xmas!
Hope you're not sweating too much without it. I really feel for you, I'd be in a spot of bother if I'd lost mine.
someguy
Post by someguy » Fri Dec 10, 2010 10:35 am
I am giving my L the work it deserves for xmas
* Engine & Trans Mounts (Possibly drop my spare RX turbo box in too)
* All front end bushes
* Driveshafts
* Suspension bushes
* Timing belt
* Pull a dent out the passenger side door then repsray it
Things I want for xmas
* Webber
* One of the rare carbed EJ engines (I refuse to go EFI :P)
* Lowered Springs
* 5 Stud conversion kit
* Brembo rotors + pads
* Respray the car gun metal grey
* AWD Liberty/Rex Gearbox with adapter plate to suit the EA82
Post by TOONGA » Fri Dec 10, 2010 2:50 pm
TOONGA wrote:hmmmmm the dual range setup Ive been looking at down my way and a scorpion low range gearing to go in it
well I got the gearbox but the scorpion low range gear set is not going to happen mind you it is a gen 1 series 1 box as I understand it
Just have to finish paying for it :( (Roll on Febuary)
Post by El_Freddo » Fri Dec 10, 2010 7:09 pm
someguy wrote:* AWD Liberty/Rex Gearbox with adapter plate to suit the EA82
Get an AWD EJ gearbox and an EA L series gearbox (both dual range or single range), split them and swap internals. There might need to be a dedent ball and spring added to the EA's box to hold low range in place when selected but its nothing serious.
TOONGA wrote:well I got the gearbox but the scorpion low range gear set is not going to happen mind you it is a gen 1 series 1 box as I understand it
Use an L series low range. A little more mucking around but it is easily done - read up on Alpine Raven's write up about it. They're the same thing anyway, just that the L series one is already used...
Hope this brings some xmas cheer!
olddog642
Chrissy stocking filler
Post by olddog642 » Sat Dec 11, 2010 7:16 pm
Well what I would like is a Brumby with a woman owner that wants to go camping with another Brumby and owner.
ehehehehe hohohohoho
Hylton:twisted:
