Symptoms leaking head gasket?
twc
Post by twc » Wed Apr 12, 2006 11:13 am
I know ive got one but just to confirm in case its something else.
What are the apparent symptoms of a leaking head gasget?
And if i have to resort to a (mechanics worst nightmare) what stop leak works the best if i need to resort to this ?
Im going down this track as the cost of repairing /replacing engine is over a $1000.00 mark . I figure ive got nothing to lose ,everything to gain??? if the stuff actually works.
mattims
Post by mattims » Wed Apr 12, 2006 12:23 pm
ive had some experience with a few different types...
theres a type with powdered copper in it. Cant remember exactly what it was called but it definetly worked better than the others i tried (nulon, chemiweld). Although it only held for about 3 months before it gave up.
r00fi
Post by r00fi » Wed Apr 12, 2006 3:08 pm
Dead give-away for blown head gasket is bubbles in the radiator or water mixed with your oil - turning it sludge
Gremlins
Post by Gremlins » Thu Apr 13, 2006 4:24 pm
I think my HG is in the early stages of failing again, and it's only been 18k kms since it was repaired last time :(
Bubbles in the radiator aren't all that noticeable (yet), but other symptoms at the moment are:
1. Misfiring at start-up after standing overnight. Car seems to run on 3 cylinders and gradually smooths out to running on all 4
2. Slow loss of coolant.
3. External evidence of coolant leakage between the head and block.
Appart from point 3 the other two symptoms are what happened last time the HG started to fail, it then progressed on to blowing the coolant out of the radiator into the expansion bottle causing it to overflow. Also, there was a sort of petrol/exhaust type smell quite evident in the expansion bottle ontop of the usual coolant smell. Fortunately I didn't have any oil and coolant mixing.
I also read on a US forum that you can get a kit that "sniffs" the coolant for the presence of hydrocarbons. If any are detected apparently this is a fairly good indication of a bad head gasket. I guess these would be available in Australia, just haven't noticed them.
coupe
seal up
Post by coupe » Fri Apr 14, 2006 5:21 pm
Try going to Repco and ask for Metalic Seal up its about $8.00
Seal up leaves no crap in the motor or radiator cores , i got 5 years out of the job i did on the EB ford and i ve got 3 years out of the vortex so far
Use The Fork Luke
tim_81coupe
Re: seal up
Post by tim_81coupe » Sun Apr 16, 2006 7:14 pm
coupe wrote:Try going to Repco and ask for Metalic Seal up its about $8.00
But you will have a real hard time if you do decide to remove the cylinder head(s) after using that product.
Does work though.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
coupe
seal up2
Post by coupe » Sun Apr 16, 2006 7:25 pm
I just removed the ford head last week .
I had no problems taking the head off and the residue was bugger all.
I have a ford ea wreck out the front which i brought thinking the head was good but when i took it off it had Chem weld or some other crap in it.
It was like white sellys no more gaps now that was a shocker it clogged up everthing.
Use The Fork Luke
Return to “Trouble Shooting”
