Does the L Series have a fuel light?
Hi all.
I was driving my brothers liberty the other day and when the fuel got low it had a low fuel warning lamp pop up on the dashboard.
I have run my L pretty low (into the red on the gauge before) and never had a light pop up but I am uncertain as to whether mine has a fuel light or not.
Some have said theirs do but it doesn't come on until after the needle gets bellow empty on the gauge. and some say they don't think they have one.
Its a 1990 Sportswagon (the Speedo only cluster, not the touring wagon tacho and speedo cluster, not sure if that makes any difference)
- Captain Obvious
no fairly certin they dont
nope they dont. I have a jap import awd cluster and it does have one. Not sure about the standard Aus delivered rx cluster though.
89 L wagon: twin carbs, kings, kybs, 2" lift, rear discs, clutch lsd, L awd box, Kumho KL71 27s
85 Vortex: ej20 G, awd, 5 stud, 17's, almost on the road!
88 Bush basher L wagon: Welded rear diff
MY10 GEN5 Outback: white, and completely normal
- Battlewagon
Is there a way of installing or making one.. possible from a Liberty?GTlegs wrote:Nope, the fuel sender AUS cars have does not have a provision for it (and hence wiring is not there)
GTlegs wrote:They all do (the little square under the 'E' letter) , but the AUS delivered ones are not hooked up.
WHAT!!!
so looking into this!!!
on the other hand with the subaru being so shite on fuel it seems mine is the only sender that works in the house hold. but even so i drive it when the needles below the little white square
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
You could rig something up (like a switch) in theory, but in practice, the fuel senders are individual for each car (and I think a liberty has two for each side of the car due to the diff hump in the tank).AlpineRaven wrote:Is there a way of installing or making one.. possible from a Liberty?
Taking out the fuel level sender out of the tank is not recommended by Subaru anyway as it would stuff it up and you would need to instal a new one.
You could buy a new JDM sender I guess, and rig up the wiring, but how you would connect it to your dash is another question as the dash gauges only have two round connectors that power all the gauges.
- Battlewagon
Ive already swapped over the low fuel unit in my wagon and it was fixed by doing that...GTlegs wrote:You could rig something up (like a switch) in theory, but in practice, the fuel senders are individual for each car (and I think a liberty has two for each side of the car due to the diff hump in the tank).
Yeah but Liberty has 1 low fuel sender on the drivers side of the tank, the left side is only pickup line.
Nope,my L DL wagon now runs a full touring wagon loom plus the touring wagon dash, never had the low fuel light on but have managed 65L fill in the tank on a few occasions without seeing any light appear. The dash does have the capacity to have a low fuel level light yet as GTlegs has said the wiring is not there - hence we do not have the correct fuel sender unit to do the job...
- T'subaru
This got me curious and my 3 L series all have it although the fsm doesnt reference it ( didnt look at the full wiring schematic) but my owners manual does, says it illuminates at 2.0 imp gallons/ 9 liters. Pretty hard to see but below E there is a 2 x 4 mm window. Ill bet the wiring is there if the right sender is installed, strange they would send Au a different fuel sender.I could be wrong but Ive added electric mirrors and interval wipers and all the wiring was in place, plug and play:)
1988 SUBARU OWNERS MANUAL out of my 11/87 made TW
page 27
Low fuel warning light
This low fuel warning light goes on with the ignition switch at "ON" when the fuel tank is nearly empty [ about 9 liters (2.4 US gal, 2.0 Imp gal)]
Guess I got lucky, and I am tired, off to sleep through a once in 4 year soccer game
page 27
Yep, maybe it does say that. I've also seen an L series owners manual that shows details of the L series AWD gearbox with lockable centre diff, but we never got that one either...steptoe wrote:1988 SUBARU OWNERS MANUAL out of my 11/87 made TW
page 27
My 88 MPFI touring wagon had a functioning fuel light.
Interesting. Maybe I could get mine going then. Ruby Scoo runs a full touring wagon loom, dash and has an EFI fuel tank from a leone royale...
So what would be missing? I know the globe is in there and when swapped to the place of another globe that's the same its a working unit.
I would presume that the fuel sender unit would be the one capable of turning that light on being that it is from a Royale model.
El_Freddo wrote: dash and has an EFI fuel tank from a leone royale...
ive got one sitting here too interested??
if it works the i might go ahead too
GETDIRTYCLOTHING
GETDIRTYCLOTHING
please, look at your sender unit and report back the number and colour of your wires. Did have two fuel tank senders as spares since binned, and they had three wires, and a funny electronic? sensor thingmyjig at the end of the non sender wire for gauge. Think many just shoot themselves early in life. The extra little booklet for Australian owners manual does not state anything about warning light not being an option
