temp guage modification?
Hey all,
I have a aftermarket temp guage, thats probe is too long, can i just cut it sorter to fit or are they tuned somwhow?
Whats your thoughts...
Smokey.
Smokey.
- tim_81coupe
As in a mechanical gauge with a nylon tube to the sender? You can't shorten them, they are 'tuned' to the length of the tube. You have to coil up the excess to get an accurate reading.
But I have often wondered about the mechanical temp gauges, I mean, in different applications there will be different thermal influences on the tube. So in one car the tube might run close to say, the low side hose of the A/C and report a lower temp, whereas in another car it may run close to the exhaust and report higher....
I just run electrical gauges where I can....
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
i disagree.r00fi wrote:I always used a mechanical (VDO - all brass) temp gauge on my Escort Twincam - the reason is that a mechanical gauge will react much faster to (possibly disastrous) changes than a (standard) electrical gauge.
It's more of an old school thing.....
the autometer electric water temp guage were imho faster to react to, and more accurate than the mechanical guage i ran beforehand.
my 2c.
1998 Subaru Legacy GTB
The temp guage is a wire attached to a long probe that screws into the block. Question is can I cut the probe shorter to fit? will it still give the same temp reading? I know I can test it before and after the cut to find the answer to my question by using a pot of boiling water. But if it doesn't read the same then its kinda too late....
Smokey
Smokey
