15 inch wheels
RedNekTJ
15 inch wheels
Post by RedNekTJ » Sun May 23, 2010 6:08 pm
I am wondering if there are any 15 inch wheels anywhere that fit a standard Brumby stud pattern? Reason I am asking is there seem to be a decent amount of standard tyres off other 4WD's around the 28 inch mark that can be had for cheap when the owners upgrade. Thought it could be a decent alternative to the cost of new 27 inch tyres at approx $180 a corner.
red_rocket
Post by red_rocket » Sun May 23, 2010 11:08 pm
mine :D:D:D:D:D:D:D
but good luck finding a set as they are as rare as hens teeth. i honestly dont think there are many if any 15" with a 4 stud pattern. a lot of the guys redrill 15" sunraysia's or other ones? its a cheaper option i guess and yes tyre range is better
L series project
http://www.ausubaru.com/forum/showthread.php?t=14491
Rolling in the 99 Rex though :D
Tozzy
Post by Tozzy » Sun May 23, 2010 11:26 pm
I ended up getting Speedy wheels. 15inch fitted with 185's. Don't do any off road stuff but they come in 5.5, 6 or 7inch series.
Photo attached.
Finished Ute.jpg (91.21 KiB) Viewed 5852 times
red_rocket
Post by red_rocket » Sun May 23, 2010 11:33 pm
they look pretty good i reckon. how much for the set?
L series project
Post by RSR 555 » Mon May 24, 2010 10:06 am
If you don't mind steel rims? then a friend got his rims made up using a 15" rim from a Toyota and having a centre piece welded in (professionally) and drilled to suit the Subaru pattern (4x140pcd). They weren't that expensive to do.. I believe it was like $100 a rim
tex
Post by tex » Mon May 24, 2010 10:25 am
Don't disregard Peugeot rims they have some nice 15" aftermarket rims just avoid the ones with the european sizes so wary of any of the ones with michelins on them!
peugeot wheel.jpg (113.7 KiB) Viewed 5848 times
87 targa brumby (Neglected),
+ others.
Post by RSR 555 » Mon May 24, 2010 11:01 am
tex wrote:Don't disregard Peugeot rims they have some nice 15" aftermarket rims just avoid the ones with the european sizes so wary of any of the ones with michelins on them!
That doesn't look like the Subaru 4 stud pattern :confused:
Post by Alex » Mon May 24, 2010 12:24 pm
redrill hubs to suit 6 stud..not rims :)
yarney
Post by yarney » Mon May 24, 2010 7:02 pm
RedNekTJ wrote:I am wondering if there are any 15 inch wheels anywhere that fit a standard Brumby stud pattern? Reason I am asking is there seem to be a decent amount of standard tyres off other 4WD's around the 28 inch mark that can be had for cheap when the owners upgrade. Thought it could be a decent alternative to the cost of new 27 inch tyres at approx $180 a corner.
There are some cheap tyres around Dane from this forum got some for around $85 14" mud tyres if he is at the meeting tonight i will ask him where he got them and let you know
Jan
Tozzy
15" rims
Post by Tozzy » Mon May 24, 2010 7:18 pm
My wheels are through a tyre guy in Mandurah but can get them from any tyre place. They are "Speedy Wheels" & made special in S.A. I believe. Took me about 3 months to get them because of the 140mm stud pattern. Wasn't in a hurry as I had the ute stripped down anyway. Cost was a bit much, around 1200bucks. I had the tyres from a friends new Suzuki Swift. She got mags put on and kept the wheels.
RedNekTJ
Post by RedNekTJ » Mon May 24, 2010 7:42 pm
I've got no issues with steel rims. Don't want to redrill hubs for 6 stud as it's my daily driver and would like to keep it as legal as possible. My next thought was to contact fourby's as I know they make custom rims and I'll see if they can do anything for me. That would be great yarney, the cheapest I've found for 14" rims have been about $180 each for new, haven't seen many second hand sets around. Cheers for the reply's.
82coupe-man
Post by 82coupe-man » Tue May 25, 2010 1:17 am
wheel workz in mentone vic can make up a set for ya for about 150 a piece, they use your standard wheel centers and put a larger step up on the middle of the ring that goes around it, I am having 15x7's made for my coupe from my 14x6's only problem I'll have is the rear tyres rubbing on the rear wheel arches when i hit a bump as my car is lowered not lifted...
IN SOOBIE WE TRUST
yarney
Post by yarney » Tue May 25, 2010 3:34 pm
Here is the tyre mob i was talking about Brisbane mobile tyres Just give Brett a call on (07) 3260 6060
Jan
Post by Alex » Tue May 25, 2010 4:20 pm
are professionally custom made rims legal?
just curious.
82coupe-man
Post by 82coupe-man » Tue May 25, 2010 10:36 pm
yeah, in vic they are, as long as theres only one weld and cant be two piece bolted if there alloy (i dont know how simmonds get through)
IN SOOBIE WE TRUST
