I've declared my current loom a lost cause:
1. I've discovered my tourer comes with a fuel return line and a fuel pump mounted underneath, so if I was to replace the current pump with something like an EA82 EFI pump would this do the job or should I still feed the surge tank with the EA81 pump and use the EA82 pump between the surge tank and the engine?
2. I curently have a 5spd FWD box that came with the motor, this will do for now, I'll upgrade to AWD later. The stub axles are 23 spline, some googling tells me that my current cv's should go onto these stub axles with out the need to replace the DOJ's with Impreza DOJ's, is this correct?
3. I need the alternator and mounting brackets, are these the same for all EJ's?
So given that my assumptions are correct, now all I need to get it running is an EJ alternator and mounting brackets, the EA82 EFI fuel pump and the prepared loom from sunspares.
Does anyone have a spare alternator and brackets or suitable EFI pump going for a reasonable price?
Thanks,
Jordan.
