hi guys
how hard would it be to put an idiot lite on the water temp (and no im not the idiot) its on the brumby and its going to be my operators hack .i just want to make sure it dont get cooked.is it an easy fix (shudup rik) or should i tak it to my sparky .
dibs
idiot lite
idiot lite
You have 3 options
1. A small op-amp to amplify the signal from the water temp sender to turn on a relay and a light.
2. Use a factory thermo-switch off a radiator (you should be able to buy them in a few different temperatures)
3. Use a thermofan controller (probably a little overkill)
Same here it's got an alarm so you don't even have to look at itgrewi wrote:Try a TM2 engine temp watchdog, it has a digital temp readout and audible alarm that can be set to whatever temp you want. See it at enginewatchdog.com or phone 3277 6770 (Signals Australia) I have one in my L Series and it works well
Cheers, Bill
good 4 wheeling.
Jan
That number needs an 07 in front for anyone not in QLD
Easy as to instal. Comes with a lighter plug. I hard wired one to my radio fuse in my GLTM. It is great.The sensor lead just goes out through firewall and bolt its eye to thermostat or rocker bolt, and you're off. Bought another for the Brumby. YOU set the temp that alarm goes off. I ummed and arghed at first - wasting precious time
Steptoe has no affiliation with the company other than a satisfied customer
