3 plug 4 plug trivia L Series mpfi
Post by steptoe » Wed Mar 03, 2010 10:38 pm
LTurbo Thomas and I discovered a little bit of trivia when we met up to test my spare 4 plug hot wire air flow meter on his car. The three plug Karman vortex style flapper afm has threaded flange holes to bolt air filter box to it whereas the 4 plug hot wire afm has just holes to bolt the afm to captive nuts on the air filter box. One has a part number ending in 40, the other - 50. Told you it was trivia
Post by Gannon » Thu Mar 04, 2010 5:16 am
Another bit of trivia,.. the flapper air flow meter and a karman vortex air flow meter are completely different bits of equipment.
We all know how a flap or vane style AFM works
But a A Kármán vortex sensor works by sensing turbulence. The air stream is disrupted and his causes a wake in the air stream and subsequently the wake will collapse repeatedly and cause Kármán vortexes. The frequency of the resulting oscillation is proportional to the air velocity.
Post by steptoe » Thu Mar 04, 2010 1:22 pm
reminds of the days when i thort constant velocity joint was a technical term for a uni joint in tailshaft ! thanks for the input
