2000 outback fuel filter location
matticuss
Post by matticuss » Wed Feb 17, 2010 8:04 pm
Would anyone be able to tell me where the fuel filter is located. Everywhere i've looked tells me its a big black canister in the engine bay but i can't seem to find it.:confused:
Thanks
Post by AlpineRaven » Wed Feb 17, 2010 8:56 pm
matticuss wrote:Would anyone be able to tell me where the fuel filter is located. Everywhere i've looked tells me its a big black canister in the engine bay but i can't seem to find it.:confused:
Thanks
Welcome to ausubaru.
The fuel filter is inside the fuel tank, i think drivers side.
FROG
Post by FROG » Thu Feb 18, 2010 8:01 am
Yep make sure you get the two o rings aswell as the filter
42072AE000 FILTER
42025AE020 O RING
42025AE030 O RING
Post by Alex » Thu Feb 18, 2010 2:42 pm
there should be one in the engine bay also. Top right corner in the engine bay.
FROG
Post by FROG » Thu Feb 18, 2010 4:30 pm
Nah in tank OR underbonnet
matticuss
Post by matticuss » Thu Feb 18, 2010 6:03 pm
thanks for the info!
Post by AlpineRaven » Fri Feb 19, 2010 3:34 pm
matticuss wrote:thanks for the info!
what did you find matt?
78sti
Post by 78sti » Fri Feb 19, 2010 3:48 pm
Lift the rear seat base (drivers side), pull back the plastic flap and unbolt the inspection cover. Then you will see the top of the fuel tank and the pump assembly. Remove all bolts and pull out of tank, you will now see the filter.
Return to “Trouble Shooting”
