Solid axel conversion for brumby
Does anyone know if there is such thing as a solid axel conversion for a subaru brumby. I know its probably a little far fetched but I was curious if anyone had ever heard of one before.
Subaru.... Not the prettiest at all but nothing else out there holds 8 people, 4wds like a truck and gets twice the gas mileage as a truck.
actuallly it doesnt seem that hard to engineer to me.
simply make some brackets axel and custom suspension mount or modify existing mount.
weld??
but my question is WHY
weld??
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- brumbyrunner
I've seen on highly modified axles on Subaru but I don't understand why you would do that, the setup what subaru has now is better than solid axle.. Thats my opinion.
Well for a start you would have to rip out the torsion tube and swing arms and replace it with either a coil spring set up or dare I say it leaf springs! If you wanted to get excited why not a commodore IRS with LSD
87 targa brumby (Neglected),
+ others.
+ others.
The main reason I want it is because im always running over rocks and ripping my CV boots. Is there like a stronger covering for them thats all I really need. I just hate constantly changing boots.AlpineRaven wrote:I've seen on highly modified axles on Subaru but I don't understand why you would do that, the setup what subaru has now is better than solid axle.. Thats my opinion.
Here you go..
http://i246.photobucket.com/albums/gg11 ... 010353.jpg
http://i246.photobucket.com/albums/gg11 ... 010350.jpg
http://i246.photobucket.com/albums/gg11 ... 010366.jpg
Phew...
- TOONGA
quite a few people have used old innertubes over the CV boot these are cut into tubes which are slipped over the joint then ziplocked into place so you have an outer rubber cover over the boot
it means you have to either have the shaft out or one joint at least to slip the tube over boot but if you are replacing the boot you have to have the shaft out to some point
never done it myself as I don't go too extreme these days brumby parts are gold plated price wise down here
- brumbyrunner
You used to be able to get leather protectors that would slip over them but apart from Ebay wouldnt have a clue where to find them. Otherwise you might be able to find some of those clamp on ones that wrap around and then just put them on over the top! Used to be a hilux we worked on had the same issue but once a week they'd have one go and that was just driving through the paddocks, The brumbys have those little flaps on the torsion tube to help prevent tearing but mine always end up bent....
+ others.
+ others.
AWESOME !! Love to know more about this Lbrumbyrunner wrote:
Now thats cool. Do those still have the same subaru engine in it? This one here has I believe a chevy 350 in it.
http://www.youtube.com/watch?v=W2mc1LGb29g
that blue brumby with the ladder bar rear suspension looks damn tough. if you want to protect the outer CV boots you could cut some steel tube in half and weld it to the trailing arm, in front of the CV joint to stop things flying up and hitting it. this is just an idea as im not near my car right now, so i cant check to see where you would weld it to. but if you are going to go all out and change the suspension, you should check out the brumbyrunner project. it has some pretty cool things done to the suspension and i am sure brumbyrunner would be able to give advice on what works
showthread.php?t=4919
- masterguitarshreader
- subalex
Getting back to reality for a moment and old Subie money... have you thought of or already tried the great old boot protection idea of welding on (or otherwise attaching) some short curved arms that lead back from the rear crossmember and hold some much larger reinforced rubber (from Clarke rubber). These can hang down long enough just in front of the CV boots so they fold under the CV boot and protect it whenever the terrain comes close enough. Rubber against rubber is a whole lot better than rubber against rock.
Try this for pictures... a link can't be made directly so...
http://www.subaclub.com/ go to "tech talk" and "drive shaft care"
'91 Sportswagon - 3" lifted, 14" speedys, 27" Nankangs + lots of small details improved. Wouldn't mind some extra grunt from an EJ.
i beg to differ with that, the amount of times that the lseries has let me down with wheel travel. but in the stock standard vitara on road tires only bout an 1" bigger in diameter i have way less trouble getting up hills in it compared to the suba. if subaru had a car with a live axle in the back, it would be in my garage.AlpineRaven wrote:I've seen on highly modified axles on Subaru but I don't understand why you would do that, the setup what subaru has now is better than solid axle.. Thats my opinion.
l series 2" lift 27"boots s/s snorkel full roof racks.
past ride 92 lib gen2 fwd wit a 2.5 quad cam conversion custom exhaust and cold air induction.
How did it let you down if its because one wheel didn't sit hard enough on the ground I've driven tritons, landBruisers Gutluxs and all sorts of live axel vehicles without LSD's in them all with the same problem. And although we used to have fun with our little suzuki after the lack of torque our biggest problem was wheel spin going up hills, which coincidentally can be the same problem with the subarus (unless you EJ them etc).banger wrote:i beg to differ with that, the amount of times that the lseries has let me down with wheel travel. but in the stock standard vitara on road tires only bout an 1" bigger in diameter i have way less trouble getting up hills in it compared to the suba. if subaru had a car with a live axle in the back, it would be in my garage.
+ others.
+ others.
