Praying XT6 bits at last .
- discopotato03
I may have found a source of XT6 brake and hub hardware bits fingers crossed but probably wouldn't use all of it so others here may be interested .
The source has all four corners/front control arms/both anti roll bars and at my request those all important front axle shafts .
The things I want most are the rear backing plates and naturally the hubs and disks , calipers I believe are the same .
At the front the factory hybridised bits I think are the calipers mounting brackets and the slide pins which use a different thread to our RS Lib ones .
XT6 front axle shafts are important because they are an in between size length wise . Basically a longer than RX , shorter than Lib , 25 spline shaft .
Lets see what Santa brings , cheers A .
You have XT6 parts in Australia?
So tell us why you arent using the all the brakes and hubs from this XT6
- discopotato03
Not yet , XT6 knuckles are slightly different to early Lib as in the bit that bolts to the strut is thicker/wider than the 2 bolt bracket on the strut .
Also not 100% sure but the CV may be slightly different too - sort of OE pre Lib prototype .
I think it would be better to use locally available front stuff but you need the XT6 caliper bracket and slide pins to get the L caliper bridge to go bolt .
I think dimensionally the early Lib rear disc is very similar to the XT6 so with a machining nip here and there should work out ok .
A .
A .
So why not go Crossbred conversion kit and use all lib stuff?
- discopotato03
- Chris_Rogers
