Unleash The note
Get the best out of your Induction & Extraction System ...
brumbydan
Unleash The note
Post by brumbydan » Sun Nov 29, 2009 9:36 pm
G'day all,
Does anybody know of a decent exhaust setup for the EA81 to unleash the iconic bruble. Mind you a gutted catalytic converter isnt enough.
Dan
Post by steptoe » Mon Nov 30, 2009 10:05 am
they used to use cat gut for stringing tennis raquets :) . I have no cat no resonator just a two inch all the way to a sports muffler at the rear. It is excellent for backing off past people on their mobie phones :) :0
Tozzy
Post by Tozzy » Mon Nov 30, 2009 7:21 pm
I've got an 89 Brumby and fitted a 2" system with one straight through sports muffler at the back. No hotdog in the middle.
Its got the burbble and has increased its power slightly.
Post by Gannon » Mon Nov 30, 2009 7:42 pm
I wouldnt wanna get caught with no CAT converter, the fines can be very hard on the wallet.
Proven design is 2" from the cat/Y-pipes back with a hotdog halfway and a straight through at the rear. If you want a deeper sound, use a 2.5" muffler on the rear
Post by TOONGA » Mon Nov 30, 2009 11:02 pm
if you want a rumble and still want a Catalytic Converter look at this one on ebay
http://cgi.ebay.com/ebaymotors/Magnaflo ... 518e43d41a
2 inch inlet 2 inch outlet
you could run one on each pipe and have a balance pipe before or after them then run it into one pipe with a final exhaust or have 2 seperate rear pipes with 2 smaller exhausts or resonators for that really noisy exhaust
kona480
Post by kona480 » Wed Dec 02, 2009 5:37 pm
I have this but have a smaller, normal muffler. Would a 5 inch cannon be better for a deeper sound?
Post by Gannon » Wed Dec 02, 2009 6:06 pm
A 5 inch cannon will look 120% more gay than a 4 inch cannon. Especially on a brumby
If you want a deeper sound, get a 3" turbo muffler and make the tail pipe as short as possible
Tozzy
Post by Tozzy » Wed Dec 02, 2009 7:46 pm
Back again. I got mine done at a muffler shop and he knew what I was talking about. He said don't bother with the hotdog in the middle, just a 2" straight through with a staight through muffler at the rear.
I was looking for better exhaust flow which I got and also a good note as a bonus.
Return to “Intake & Exhausts”
