Liberty Gen 2 Auto into Gen 1
Will a Liberty Gen 2 Auto bolt onto Gen 1? This is will a Auto out of a Gen 2 1994 Liberty bolt up to a Gen 1 1993 Liberty?
The auto in question is a 4 bolt model.
Thanks
Matt
Thanks
Matt
"Claudia"
"Claudia"
Should do. The Gen1 and Gen2 are basically the same platform. Just double check the wiring pinouts. Im guessing both engines are EJ22's
Unsure on the liberty it is going into.
Also the auto is manual control, not computer???
"Claudia"
"Claudia"
Its a 4 bolt so it'll work.
Both engines are EJ22.
The connections are different but if you have existing tranmission, just swap the wiring/plugs over.
I don't know about the final drive, but I'm pretty sure its 4.11.
Edit: For sure Gen 1 has 4.11, but I'm pretty sure Gen 2 also has 4.11 as well.
All EJ auto's (4eat as they are known) are computer controlled. They will simply not work right without the TCUMatt wrote: Also the auto is manual control, not computer???
I thought they where computer controlled or controlled be the TCU.
"Claudia"
"Claudia"
- vincentvega
bolt the box up, plug it in and drive. no modifications required.Matt wrote:Will a Liberty Gen 2 Auto bolt onto Gen 1? This is will a Auto out of a Gen 2 1994 Liberty bolt up to a Gen 1 1993 Liberty?
Thanks
Matt
- vincentvega
Thanks fella's that is the answer i thought you would say, is that it will bolt up and will be driveable.
"Claudia"
"Claudia"
