Brumby alternator issue
Hi all, I have what might be a dumb question for you. I have been having electrical issues with my brumby in the form of the battery going flat rapidly, i have put a known good battery in and the same thing has happened. I started the car today and removed the terminals to test what output the alternator was giving and it was reading 9 - 10 volts.. i did the same test on my l series and it tested 14.5 which sounds more like its meant to be to me. could it be possible that my alternator in the brumby is cactus and is shorting somehow and when its not running it is running the battery flat?
sounds like you found the problem and just needs some thinking....it is not enough to give your battery the correct charge. I'd say it needs new bits. Try proving it to yourself by swapping alternators between your two cars and watch the L develop same symptoms your brumby is displaying. Not shorting just not working correctly.
- phillatdarwin
