fast ej22
aspro
fast ej22
Post by aspro » Mon Mar 13, 2006 1:06 pm
Just done an engine swap... ej22. Seem that the new donk wants to idle fast, it didnt before. Any suggestions on where to start?
bluesteel
Post by bluesteel » Mon Mar 13, 2006 2:35 pm
throttle cable not adjusted properly?
breather hoses?
also check for engine codes it might even tell you whats wrong
Post by AlpineRaven » Mon Mar 13, 2006 2:48 pm
or air leaks? Sometimes if you have an air leak it'll idle fast.. or um throttle cable needs adjusting?
Post by AndrewT » Mon Mar 13, 2006 3:12 pm
Mabey do a factory reset on the ECU (i think you leave the battery disconnected overnight?? somebody confirm?).
It might be having some slight issues with running a different engine now. (even tho they are the same model of engine theres bound to be some tiny differences in the sensor readings etc).
a.
BlackMale
Post by BlackMale » Mon Mar 13, 2006 4:09 pm
And if all that fails how much faster is faster?
Post by AlpineRaven » Mon Mar 13, 2006 4:51 pm
by the way.. what revs is it showing?
aspro
Post by aspro » Mon Mar 13, 2006 5:37 pm
Mmm good question, no tacho and i cant count that fast, my guess is that it is about 1000 to 1200 rpm
Air leaks.. i will investigate, throtle cable looks spot on.
I think tis maybe the case as when it was first started it seemed to hunt. started fast then went low.... picked up speed then settled at a nice rate.
The next time it started it was fast and seemed to stay that way.
I think perhaps the ecu is a little confused. I thought it would have settled though. I will try unplugging it again. :?
tim_81coupe
Post by tim_81coupe » Mon Mar 13, 2006 6:44 pm
No no no.... :P
An ECU reset won't do anything. A vaccuum leak is a possibility though.
Wind the little screw under the throttle linkage out a bit, see if that can lower it. Also, loosen the two screws on the bypass air controller and turn the unit a bit until the idle smoothens out. Sometimes that can give a fast idle too.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
SuBaRiNo
Post by SuBaRiNo » Mon Mar 13, 2006 10:36 pm
I do recall Jays throttle body have an incorect idle adjustment on it. I know on mine and every other EJ throttle body i have looked at.... the top adjustment screw on the top of the throttle linkages... which appears to be the idle adjustment... in fact is not... and this screw should not be stopping the linkages returning to there rest point. I think that made sence. I know what i mean. Try that if u get me.
Dave
tim_81coupe
Post by tim_81coupe » Mon Mar 13, 2006 11:31 pm
The one that the base of the linkage rests against under return spring pressure is the idle adjustment.
Well it is on my EJ20G and on my EJ16.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
SuBaRiNo
Post by SuBaRiNo » Tue Mar 14, 2006 8:28 am
Thats right... the one on top... is not.
Dave
aspro
Post by aspro » Tue Mar 14, 2006 11:45 pm
ah ha!, hadnt seen that lower screw. half a turn and now its where it should be. Thanks Tim. :D
tim_81coupe
Post by tim_81coupe » Wed Mar 15, 2006 12:17 am
No worries dude :D
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Return to “Trouble Shooting”
