While reading through the VSI-8 (vehicle mod guide for Vic) the other day, i noticed that it specifically mentions that track width increases are strictly prohibited for vehicles with a combination of front-wheel drive, Macpherson strut suspension and negative scrub radius geometry. I knew L-series/Leone fit the first two, but i had no idea what the third requirement was. This had me intrigued. A bit more Google searching and i came across this excellent site describing all the aspects of steering geometry and wheel alignment which i highly recommend reading. Very enlightening:
http://www.familycar.com/alignment.htm#Scrub%20Radius
The term SAI they use is basically a straight line through the middle of your strut to its equivalent point on the ground. On scrub radius they say..
Based on this and the fact the the L series has a positive camber (which always totally bemused me in the past), i figure that the reason for the positive camber is to induced negative scrub geometry to improve vehicle handling (e.g reducing torque steer). Now this has me thinking that the desert rat rims I'm using which substantially increase offset is creating positive scrub radius, negatively effecting steering performance, and is technically illegal in Vic. More than likely it contributed to the huge (scary) increase torque steer i experienced after my EJ25 conversion, beyond just the power increase of course.Scrub radius is the distance between where the SAI intersects the ground and the center of the tire. This distance must be exactly the same from side to side or the vehicle will pull strongly at all speeds. While included angle problems will affect the scrub radius, it is not the only thing that will affect it. Different wheels or tires from side to side will cause differences in scrub radius as well as a tire that is low on air. Positive scrub radius is when the tire contact patch is outside of the SAI pivot, while negative scrub radius is when the contact patch is inboard of the SAI pivot (front wheel drive vehicles usually have negative scrub radius).
If the brake on one front wheel is not working, with positive scrub radius, stepping on the brake will cause the steering wheel to try to rip out of your hand. Negative scrub radius will minimize that effect.
Scrub radius is designed at the factory and is not adjustable. If you have a vehicle that is pulling even though the alignment is correct, look for something that will affect scrub radius.
Now I'm also wondering whether adjustable strut tops, which i was considering for the purpose of inducing neutral camber and additional positive caster, will also negatively effect scrub radius. I'm thinking though that adjustment to the strut angle produces a lesser change in the camber angle, so if anything it may create additional negative scrub radius? Not sure at that one.
It is also interesting that they specifically mention vehicles pulling left or right and scrub radius geometry. It reminded me of problems with Liberties pulling to the left that AP and some others have had, despite having excellent wheel alignment specifications on their vehicles.
All food for thought. Feel free to comment/discuss/dispute. Personally I'm now seriously considering a set of standard offset (or closer to) set of 14 or 15 inch rims for my L series. I'm curious if this knowledge changes peoples thoughts on their wider off-set rims if they have them/thinking about getting them. Makes it hard considering they're the easiest to source and cheapest 14" rims around.
Rhys
