EJ timing cover question
- TOONGA
I need some info on ej16, ej18 and ej22 SOHC timing covers
1. are they the same length for all these motors?
2. if not are the ej16 and ej18 covers interchangeable?
3. how many internal guides are inside the covers?
4. how long could you run an engine without the covers?
thanks
thanks
not sure. If you want i got some covers here for ej22. Running without the covers would let water and dirt get in, it could make the pulleys start to rust or something can get caught between the teeth and cause the belt to slip.
why would you want belt snap for?
EJ18 & EJ22 are the same, havent came across to EJ16 yet.
Does it happen a lot in EJ engines?GOD wrote:Slap, not snap. The guides in question are mounted very close to (but not touching, I guess) the back of the belt on the pulleys, to stop the belt from jumping around too much in rapid acceleration/deceleration.
Dane.
That is what I thought, I thought for one minute thinking it must've been me not revving hard enough with my EJ22!GOD wrote:Today is the first time I've heard about it. Did some reading, and it seems to happen mostly in highly tuned turbo engines running high lift cams.
Dane.
