I want intermittent wipers
Post by steptoe » Tue Sep 15, 2009 9:56 am
Has any electrical genius any clue on how to add an L series or luxo MY intermittent wiper control into a non luxo Brumby? I have seen some Brumby;s and MY's with intermittent wipers. My BWumby don't and needs. I have two different looking units marked intermittent wiper from either L or MY, one has six wires, another eight.
Hella do a $195 kit the 7010, I am looking more cheap and cheerful than that.I bought one about quarter of a century ago for about $30. It had clear instructions on how to determine what sort of electrical system was in use in your car.
It needed to tap into the earth return wire of the car wiper system, the low speed circuit and had adjustable (dwell) knob that was also its on/off and would only work once wipers were on.
Anyone know how to wire up?
dukbilt
Post by dukbilt » Tue Sep 15, 2009 10:43 am
Can you provide some photos of the units that you have? Also, do you have a spare wiper switch? I want intermittent wipers too - and I'd like to incorporate it into the wiper switch itself (replace the present three position switch with a similar-sized four position switch). I'm not after variable dwell - I just want one speed. That circuit is simple to make, and I'll look at it at the end of the month.
Ewan
Post by steptoe » Tue Sep 15, 2009 1:27 pm
I'd have an L series wiper switch somewhere. If it is a Brumby switch you are after I will check another avenue I have to find.
Post by AlpineRaven » Tue Sep 15, 2009 3:58 pm
other thing you could install variable speed control wiper in.
discopotato03
Post by discopotato03 » Wed Sep 16, 2009 12:34 am
What my mate did was change to the intermittent type switch and apparently there is a gadget that looks like a flasher can you need as well .
Steve reckons the wiring is all there but need the switch and can .
A .
Post by steptoe » Wed Sep 16, 2009 2:25 pm
I have one of those cans, need to go look for a switch and have a play then, nice tip A.
Post by steptoe » Sat Jan 21, 2012 9:16 pm
OK, two years and four months later ....
I can provide pics ....soon
Uploaded with ImageShack.us
and maybe close this post thread and use newer one >>>>
showthread.php?t=21302
Post by steptoe » Fri Apr 06, 2012 9:10 pm
turns out that, this pictured baby is same as an L Series module - maybe I stuffed up. Problem should be solved when I fit my Hella unit
Post by Gannon » Fri Apr 06, 2012 10:49 pm
If you have a wiring diagram of the MY wiper system, i'll show you how to add the l series intermittent thingo
Post by El_Freddo » Fri Apr 06, 2012 11:02 pm
Gannon wrote:If you have a wiring diagram of the MY wiper system, i'll show you how to add the l series intermittent thingo
That'll be sweet! I need to nut out the intermittent wipers on Sunnie the Brumby - he's got them wired in by someone like ourselves, but I need to work out what they've done to get them to work again!
Good times, at least it's going to be...
Post by steptoe » Fri Apr 06, 2012 11:42 pm
You just want my FL box Gannon - where were you before ??
I thought I could work it out, maybe with a fuse in every patch lead, but have no idea of the circuit of the L grey box makin' things harder or impossible or not safe - gees I had a gutful of that project.
Post by Gannon » Sat Apr 07, 2012 9:05 am
Well yeah the fuse link box is what I'm after, but dont think I wouldnt have replied to this thread if I wasnt in need of one. But I will need somebody to post a diagram or 2, even if its from a Gregories or Haynes manual.
