Faulty Codes
Faulty Codes
Have 2 fault codes ej22, Cam angle sensor + coolant temperature sensor.
The timing is advanced. How? Plugs are good, leads are good.
Engine runs ok but pings under load + flat spot when accerelate hard.
Thoughts?
Thoughts?
cam angle sensor fault code
hay guys havent bin on in ageers, bin busy fixinbg suby ofcorse. ive got a cam angle sensor fualt code coming up. could this b cambelt timing? the sensor looks alright. any thoughts wuld b much helpd ta
Check and count how many flashes while you're in test mode and you'll be able to tell you what is wrong.
I pulled the cam angle sensor out and cleaned all contacts. I tested it as per Haynes manual it was ok so I cleared code and has been fine since. Temp sensors was dead and needed replacing recently Knock sensor needed to be replaced.
When my timing belt was out a notch, motor ran rough but no cam angle code
