Td 035 turbo ?
seagull
Td 035 turbo ?
Post by seagull » Wed Mar 01, 2006 2:08 am
Can this be used ( bolted on ) to a rs & is there any good things about doing this or should I just go to bed a dream about girls ?
Post by AndrewT » Wed Mar 01, 2006 2:16 am
I believe its not too hard to fit one on physically but you really need an aftermarket ECU (like a PowerFC or the like) to take advantage of it with a custom tune. Larger injectors will also most likely be required.
Is this for your offroad Lib? Remember you want to go for a relatively small turbo, otherwise you will have a huge turbo lag to contend with which isn't desirable offroad.
I'm starting off with a standard VF8 turbo with my RS Lib engine (for offroad). Possibly might try something bigger later. :D
Outback bloke
Post by Outback bloke » Wed Mar 01, 2006 5:25 am
It is early and I have just woken up but isn't the turbo you mention from a Forester? Not worth putting on at all.
jzk25
Post by jzk25 » Wed Mar 01, 2006 10:21 am
TFO35HM from an Aus Forester GT is at the bottom of the food chain, it's tiny and makes power between 2 and 4k rpm.
mattims
Post by mattims » Wed Mar 01, 2006 10:41 am
hey im pretty sure my turbo is smaller than that.. well both of them are.
Post by AndrewT » Wed Mar 01, 2006 3:19 pm
ah, I think i was getting mixed up with the VF series 8O
subanator
Post by subanator » Thu Mar 02, 2006 1:09 am
Would it be any advantage for upgrade for a EA82T ?
I was thinking along the lines that it makes its power in the same area and may add more huff due to being a later design in turbine scrolls (broader spread in later ones) and is is roller bearing?
Outback bloke
Post by Outback bloke » Thu Mar 02, 2006 5:20 am
I think it would be well suited to an EA82 as an upgrade. I don't know of any one that has fitted on yet though.
seagull
Post by seagull » Fri Mar 03, 2006 1:26 am
I am going to buy this for my lawn mower .
jzk25
Post by jzk25 » Fri Mar 03, 2006 9:04 pm
IMO it would be ideal for an EA82T. It would give the same response as the clunker RHB5 but have good top end. And it wouldn't self destruct like an RHB5. They are worth very little too.
subanator
Post by subanator » Fri Mar 03, 2006 10:55 pm
This is for the backburner for me at the moment, have to sort other bits on mine first. But saying that, my dump pipe needs replacing and if I was to make one, it could be done just as easy for a TFO35HM, but not sure how much mods required in the compressor mounting side however.
What is the ball park figure for one of these?
seagull
Post by seagull » Sat Mar 04, 2006 1:14 am
$50.00
Outback bloke
Post by Outback bloke » Sat Mar 04, 2006 5:01 am
The compressor mounting part is not difficult but ther eis a bit of dicking around. You need to modify the base where it bolts on as one of the bolts is different. You also have to fiddle with the throttle cable or the turbo to get it to work again due to the compressor side of the turbo pointing directly at the cable instead of vertical as yours is now.
Intercooling is also suggested once you go to one of these turbos.
subanator
Post by subanator » Sun Mar 05, 2006 11:10 pm
Seagull, PM sent.
Thanks Brett for the info.
