do MY and L series have the same rear axles?
brenton
Post by brenton » Mon Jun 29, 2009 10:45 pm
hey guys do the MY and the L series have the same length rear axles, the l series is a carby car. ive got broken boots on the back of my l and i can get some MY axles complete of a mate? are they interchangeable
cheers brenton
Post by El_Freddo » Tue Jun 30, 2009 12:39 pm
G'day brenton!
I believe the two shafts are interchangable but the L series units are the best to use as they are designed for the L - the MY shafts have two CV cups that allow the shaft to lengthen/shorten, the L only has one like the front shafts... I don't know what running the MY units on the L will do to their longivity.
I'd look for the L series units - you can still drive around without the rear shafts in without any problems, just don't engage 4wd on the fly, there could be some nasty grinding sounds and it won't do anything for you anyway...
Post by steptoe » Tue Jun 30, 2009 12:51 pm
I don't 'know' but guessing as the diffs are the same dimension and the L is wider than MY that MY rear shafts will be too short/narrow. I thought both had double off set joints DOJ's at each end of the rears.
Phizinza
Post by Phizinza » Tue Jun 30, 2009 1:24 pm
No, "L series" rear axles look about 30mm longer then "MY" ones.
The wheel base is much wider on the "L series" then the older "MY". The "L series" is about the same width wheel base as all Hilux's, good for driving on sand as you sit in the runs instead of getting bogged down by pushing new ruts. Ok, little off topic there.
brenton
Post by brenton » Tue Jun 30, 2009 7:00 pm
alrite well i guess ill just reboot the doj on the rear then. are the l and my boots the same. my local shop only has my ones.
cheers brenton
brumbyrunner
Post by brumbyrunner » Wed Jul 01, 2009 12:07 am
There are 2 types of L series rear shafts.
The early ones had 23 spline outside x 22 spline inside DOJs on both ends, the same as MY but, as Phizinza said, are about 30mm longer and cannot be interchanged.
Later L's changed to an outer CV and this continued through to the Liberty.
Settlement Creek Racing
Post by El_Freddo » Wed Jul 01, 2009 8:43 am
brumbyrunner wrote:There are 2 types of L series rear shafts.
This is what I was thinking of but forgot the extra width of the L...
There's your answer Brenton!
