Front axle nut torque
Can someone tell me what is the correct tension for the front driveshaft retaining nut? i know its bloody tight, but the Gregorys I have doesnt want to tell me how much, just do it up to specs without giving the specs and ive looked in the Tech manual on here and cant seem to find it either. On an L series please
Suby Newbie
Suby Newbie
Your right about my tension wrench Steptoe,only goes to 150 ft-lbs. but no matter, I was only curious as to what the torque should be.Like your tecnical method and if I need to use it myself hope you dont mind.
Suby Newbie
Suby Newbie
- subybrumby
This has been covered before. They need to be supertight. I'm about 6'1" and 130kg. I really push them with a breaker bar and extension pipe and pull them up to the next split pin hole that I think I can get them without bustin the whole show. If you don't get them tight, they will make a noise and probably stuff up your cone washer etc.
So i used the method of 130kgs over 150cm pipe on a 3/4 inch breaker bar and got it tight enough to stop the funny noise it was making, thanks for the advice, I was a bit worried about breaking something. I have broken things before without trying this hard. Anyone ever broken something doing these up?
Suby Newbie
Suby Newbie
- discopotato03
Whoa there gutzits , 180 ft/lbs ?
My 87 L factory WSM quotes 145 ft/lbs or 196 Nm or 20 kg-meters .
I cant remember what my 1/2 " drive torque wrench goes up to and I don't use it anyway . Thats what the 1/2" drive breaker bar is for .
I do mine up until it feels right then line up the slots in the castelated nut with the drilling in the CV joint . Always line up tightening , the WSM says 145 and can go another 30 deg rotation to line things up .
The bearings in these hubs are deep groove annular contact type so its not like you are pre loading tapered roller bearings .
If you use the correct sized split pin I doubt very much the nut will shear it through both sides .
Also under the jesus nut (hellicopter talk) is a thick slightly conical spring washer . Even done half right there's no excuses for getting it wrong .
I've had the shafts in and out of my RX three times for joints/boots and never had a problem yet , still running the bearings and seals it came with so they've something more than 51K on them .
A .
A .
Yes correct, I did do that. I always went by the old "as tight as you can get it" maxim...but I must be stronger than others...or at least heavier as I was standing on the breaker bar when it happened! Now I just go by "as tight as I think the average pussy can get it" - well I pretty much do it by feel now I know what the breaking point is.El_Freddo wrote: I remember reading that Andrew T striped the thread off the shaft- please corrent me if I'm wrong AT.
Idealy people should go by the factory torque settings and then add abit to account for shitty flogged out washers etc.
EZ30 L series - Monsterwagon
- subybrumby
