some photos:
This is the Injector block, which forms the bottom part of the manifold, one on each side, coolant crossover casting mates-up to these:
This is what they ports are like, much better than the carby EA's thats for sure! :
This is how the whole thing looks and measures, without all the vaccum / fuel lines under it:
You can really see just how large the plenum is:
This is the intake top mounted the Correct Way (throtle facing rear):
Reversed (facing forward - shorter intake length with FMICs):
What it fouls when reversed - EGR input, just bend the vac. lines, or use 3mm silicon hoses!:
Plenum is plenty big enough for a larger throttle or twin throttle even!:
