Which WRX rack fits L RX Turbo ?
discopotato03
Post by discopotato03 » Thu Feb 05, 2009 12:26 pm
Hi all , can someone tell me which Impreza WRX steering rack goes bolt in an L RX Turbo . I'm interested in less turns lock to lock and one of the early ones goes in I'm told .
I wouldn't be surprised if the L ones tie rods had to be transfered but that shouldn't be a biggie .
Cheers A .
BrennyV
Post by BrennyV » Thu Feb 05, 2009 2:42 pm
The older gc8 racks will fit fine, you will need to run the l series tie rods on the impreza rack. You would be best finding a rack from a older ra sti as they have the least.
Hunter S. Thompson
Matatak
Post by Matatak » Thu Feb 05, 2009 5:33 pm
yups i had a GC8 WRX rack with the 2.7 turns lock to lock, instead of the usual 3.7
much much much better to drive with especially offroad.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
discopotato03
Post by discopotato03 » Thu Feb 05, 2009 7:50 pm
Thanks guys , I was hoping GC8 (all through and inc MY2000 ?) racks fitted up in the std L mounts and to the std L hydraulic hard lines at the rack housing .
I know of one in Victoria but if someone up here in Sydney can spare one in a rebuildable state ...
Cheers A .
brex
Post by brex » Wed Feb 11, 2009 5:46 pm
Hi,
Guys does this work on MY model brumbys or not.
Cheers Brex
Brex: Brumby rex
Matatak
Post by Matatak » Wed Feb 11, 2009 6:59 pm
brex wrote:Hi,
Cheers Brex
Yep
i had one in my MY wagon.
Post by Gannon » Wed Feb 11, 2009 7:52 pm
Just slightly off topic, but can you put an L series steering column in a MY?
PeeJay
Post by PeeJay » Thu Feb 12, 2009 5:43 pm
I think I've got a '96 rack in mine.
brex
Post by brex » Thu Feb 12, 2009 6:35 pm
Gold can you give me some details on wats involed?
Cheers Brex
Brex: Brumby rex
timmo
Post by timmo » Fri May 15, 2009 2:02 pm
just tried to fit a GC8 rack to my l series. It defintely wont work in an unlifted car, the angle of the input shaft is different so it fouls on the turbo dump pipe and the linkage isnt long enough either.
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
discopotato03
Post by discopotato03 » Sat May 16, 2009 1:20 pm
One day if I can find the time I'll remove a rack from an L series and a first gen Lib at the wreckers , from memory the ratio is not quite the same as an Impreza but it is a tad faster than a turbo L .
A .
timmo
Post by timmo » Sat May 16, 2009 6:42 pm
gc8 imprezza and early lib racks are interchangeable, so neither will bolt straight up to an unlifted L series. A rebuilt L series one is going back in mine. At least i have a spare for my RS now
twilightprotege
Post by twilightprotege » Wed Oct 28, 2009 9:01 pm
bringing an old thread back to life (well not that old), but i'm looking at changing my steering rack in my L RX for a wrx one.
what's a good price for one? and is it only the GC8 wrx rack that works?
Post by AndrewT » Thu Oct 29, 2009 2:51 pm
Should be able to use any rack.
A good rack from a GX liberty could cost around $100. You can get the quick ratio STI ones too, people can charge up to around 500 for these. Depends on kms and what kindof person is selling it tho.
Careful though, if you put an EJ component in your L series it won't be an L series anymore. If you are a true purist you wouldn't even think of doing something so horrific :)
twilightprotege
Post by twilightprotege » Thu Oct 29, 2009 8:08 pm
cars are meant to be modified and improved ;)
that's good that any impretzle rack will fit - very good to know! thanks!
someguy
Post by someguy » Thu Oct 29, 2009 8:55 pm
Hmm my steering rack is almost cactus and there is a few gen 1 libertys at upullit at the moment.
Maybe I should consider grabbing one for my L Series.
discopotato03
Post by discopotato03 » Thu Oct 29, 2009 10:43 pm
From memory the series one Libs had a fractionally faster rack ratio than an RX L so provided it all falls it that would be a bonus .
A .
Post by AndrewT » Fri Oct 30, 2009 12:01 pm
Oh one thing, if you happen to get a "sporty" steering rack from a Legacy, the splined part that passes through the engine crossmember is quite abit bigger, you need to grind the hole out abit. Also you need to put +12V on the "sporty" solenoid otherwise the steering is fairly heavy, although Alex found it acceptable without the solenoid engaged on his.
twilightprotege
Post by twilightprotege » Fri Oct 30, 2009 1:39 pm
thanks for the advise!
Post by El_Freddo » Fri Oct 30, 2009 3:56 pm
AndrewT wrote:Careful though, if you put an EJ component in your L series it won't be an L series anymore. If you are a true purist you wouldn't even think of doing something so horrific :)
So if I put a nissan "go faster part" on my EA, its still an L series??? :p
I didn't know the lib/impreza racks are a direct drop in... interesting. And I would've thought that a rack with more turns would be better suited to offroad driving as it wouldn't be as difficult to turn or wouldn't throw the driver out the window when there's feedback from the steering... My thoughts anyway.
PS - I'm loving my powersteering since shoving that in with the EJ!
