Drive Brumby in FWD on dirt = write off
An olde acquaintance of mine advised me of the passing of his Brumby. Was travelling along a poorly graded road near home and got stuck in the bulldust that should not have been there if road was better done by council (use a bit of water and a roller! ) and next thing he knew he bit the embankment and rolled. Clever part was landing back on the wheels - so upright. Left him shaken for a while and sore bits but OK after a few days. The Brumby was a write -off and in the hands of the insurers.
I thought to ask if he had forgotten to slip her into 4WD when he left tarmac. Didn't forget - never has in 15 years as he says he only slips her into 4 on slow rough country not dirt roads. In this circumstance I don't think even 4WD would have prevented his little disaster.Might check my subie owner manual to see if it actually recommends 4WD action for all non tar surfaces.
In my Brumby when it had EA81 and a 4sp box I used 4WD everywhere except in carparks, lol. Still have that 4sp, used it in the race wagon, strong as ever..
I'd say, if you have 4wd and don't use it on dirt roads your
I agree with maxxair entirely. I love how stable and surefooted my Brumby feels in 4WD at 100 kph and a sometimes a bit more on those open nicely graded gravel roads.
I have noticed since running 50 series tyres there is less give and the gearbox tends to stiffen up more than with 70 or 75 series profile tyres in the drier road conditions.
I was surprised the old boy did not use 4WD often.
- brumbyrunner
- maxxair
you can slot into 4wd at ANY speed in my L, without the clutch(so long as your going straight). i do however clutch it to go to low range. im running 3WD atm and in 4wd all the time as i took out a front CV. think i need to remove the other side as its a bit weird doing burnouts and doughies (a novelty to a longterm L owner) this is the second car i have run like this
i have never broke a rear cv. i have killed MANY fronts.
interestingly they handle Far better as RWD thean FWD, not changing lanes over a small bump in the road. takes a little while to get away from the FWD mentality of more steering, more throttle. just doesnt work with RWD. rain drifts are HEAPSSS SICKOOO. lol
hijack ova:)
hijack ova:)
- the gumbi brumby
When I was in Tasmania about 2 yrs ago, I was slightly a bit too fast on very loose gravel (left big bulldust behind me!) and almost lost control and I didn't have the time to muck around with gears so wacked in 4WD low and got me out of trouble after a couple of swerves.. and thought lucky I have Low range & AWD in my Liberty!
so just a quick question guys,
My understanding of the L series duel range is that it binds up when cornering when the tyres can't slip eg tar sealed roads because it has no centre diff. But it's ok on dirt, gravel, ice/snow etc
let me know if this is correct or not, i would rather use 4WD on a loose surface road, and what top speed could you go safely
cheers
cheers
jim, correct.
Top speed I'd say 100kmph
Depends on the conditions. For most people I would say I drive at a high speed on dirt, the normal 100km/h speed limit is not a problem for me if the conditions of the road and weather are good.jim wrote: what top speed could you go safely
Effectively you could be in 4wd when the top speed has maxed out, binding will slow the top speed of your subi as already stated.
PS shame about your mate's brumby steptoe, hope he's alright.
- Thrillbilly
- Outback bloke
- the gumbi brumby
