Ebay Superchargers
indy
Post by indy » Sat Jan 10, 2009 3:26 pm
my cousin got a supercharger kit off a toyota soarer, is it possible to hook it upto my ea82 carby sportswagon??
Storm
Post by Storm » Sat Jan 10, 2009 3:52 pm
indy wrote:my cousin got a supercharger kit off a toyota soarer, is it possible to hook it upto my ea82 carby sportswagon??
Anything is possible but why would you do it?
Suparoo wrote:Yes, but flowing around the throttle is gonna mess up any spiralling of the air.
Then so will a valve opening and shutting a couple hundred to quite a few thousand times a minute. Read up on air dynamics is actually quite fascinating.
Suparoo wrote:But the idea is to turbulate the air as it flows past the injector and make a consistent air/fuel mix. They only operate at idle and cruise to give better emissions and fuel economy. Read the latest EJ25 FSM, it explains why they are there.
I really doubt you want turbulance in the air flow. These things are designed to create a faster columm of air not to slow it down by creating turbulance. If anything turbulance in the air stream will stall the air/fuel mix and create emissions problems because of irregular a/f ratios.Any links to the EJ25 FSM?
Suparoo wrote:I thought you meant modern Toyotas.
I don't know how you got that from "Toyota have been putting directional veins in the air intake for years, its nothing new."
Suparoo wrote:Is the device in your landcruiser before the air cleaner? Cos i have seen on tractors/earthmoving equipment ect. they have devices to make the air spin and separate the dirt from the air before the air cleaner.
Yes it is but a tractor that moves along an less than 20 km/h is a totally different kettle of fish than a car that moves at speeds ranging from a crawl to over 100 km/h. A tractors air vane is also alot further from the air cleaner in most cases and has a dust trap attached. The design of the Toyota air cleaner assembly helps to remove the any dirt from the air stream and I doubt an air vane less than 15 cm away from the air cleaner is going to take much dirt out of the air stream before it has a chance to get filtered anyway. The air vane doesn't remove dirt before the air cleaner, that's why Toyota have a vacuum switch mounted on the air cleaner assembly connected to a light in the dash to tell you if your air cleaner is a restriction and not doing its job anymore.
steve_rising_sun
Post by steve_rising_sun » Sun Jan 11, 2009 10:00 am
I have fitted up a lot of these to Subi's they work very well.
Steve
indy
Post by indy » Sun Jan 11, 2009 8:50 pm
is fitting a supercharger to a l series a painstaking process? or relativley simple? and what sorta power increase would we be talking :D
fredsub
Post by fredsub » Sun Jan 11, 2009 10:34 pm
indy wrote:is fitting a supercharger to a l series a painstaking process? or relativley simple? and what sorta power increase would we be talking :D
for bolt on would have to be rather modest, unless you want motor to detonate. Normally Carby ea82 has a compression of +9or so/
Interesting , would be easier for a MPFI motor though, no?
Wonder if Steve builds the engine for it to cope also.
Anything good and worth having wouldn't be cheap I imagine though.
