Popping the bonnet on an L wagon when the cable's broken?
Does anyone know how to release the bonnet on an L wagon when the release cable is broken?
I can access and move the lever at the front with a wooden ruler, but it seems I need to actually release the catch first.
To complicate things slightly I've got a big bullbar on it from which I've removed the spotlights, but still don't have room to remove the front grille.
Any advice would be appreciated - my saturday is disappearing rapidly!
Jono
Jono
I guess you would have worked it out by now:mrgreen::mrgreen:........
hehe, trying to remember what I did, I think hand through the grill...you need to move the latch sideways.....
anyway, take some advice from a hard earned lessen, I was a slack arse and never fixed it,............
got a fire under the bonnet, I suppose if I could have more easily popped the bonnet, could have helped....as it happened it was a write off, even the firerys who were there in minutes had trouble releasing the bonnet, by which time the front was well and truly burnt and stuffed.
we did that on L series once, it broke once and i used a bike hand brake thing that you attach the cable with allen key.. anyway we removed the grill and pulled back with screw driver to unlock the bonnet...
I wonder if its a common problem for subarus?
my leone hasent had a cable for years. it takes 5sec's to pop for me (bullbar makes access easy also)
Hunter S. Thompson
Hunter S. Thompson
I have no grill in my L and I can open the catch by putting my hand behind the support bracket to release the catch.
I might try some heavy gauge wire on the catch release and put the grill back in, as it seems that this is not uncommon and a new cable might do the same again.
The end of my cable came off once when I was pulling the cable inside the car and the inner cable came up through the outer before I twigged what was goung on and because it had frayed up I could not put it back in.
Suby Newbie
Suby Newbie
