Need some help Perth
seagull
Post by seagull » Sun Feb 12, 2006 4:09 pm
I having some issues in starting my ej20T in the liberty
no starter at all
I have a single green with black line comming out the main fues box in the motor bay near the battry .what does this connect to ?
seagull
Post by seagull » Mon Feb 13, 2006 1:04 am
ok I am lost as to whats going on with this machine .If some one can drop passed a lend me a hand I would be thank full .I will buy them a nice cold beer as well .
you can then get a look at my creation and its mods
cheers seagull
O I live in Kewdale as well
BlackMale
Post by BlackMale » Mon Feb 13, 2006 10:46 am
If i can get down that way i'll drop you a line
seagull
Post by seagull » Mon Feb 13, 2006 11:44 am
cheers I will pm my home number
SuBaRiNo
Post by SuBaRiNo » Mon Feb 13, 2006 8:25 pm
Where do u live Seagull?? Im good with wires.
Dave
seagull
Post by seagull » Wed Feb 15, 2006 11:21 am
I am down in Kewdale mate , I will pm my home number to you .
I have taken a few days off work to get this sorted .
SuBaRiNo
Post by SuBaRiNo » Wed Feb 15, 2006 8:30 pm
You live in Kewdale?
Dave
seagull
Post by seagull » Wed Feb 15, 2006 11:32 pm
Correct Mate kewdale I pm you my address & phone number
seagull
Post by seagull » Wed Feb 15, 2006 11:39 pm
To day I tested the wiring & I found a plug in the wrong spot I corrected this and now have the motor turning .
There is fuel in the line 250kpa and comming out of the return back to tank .
I have spark at the plugs >>> but the plugs are dry !
whats going on ??????
injectors dirty ? ideas as I am very lost guys
seagull
tim_81coupe
Post by tim_81coupe » Thu Feb 16, 2006 12:01 am
Are your injectors firing? 250kpa sounds about right, shouldn't be a problem there.
It would have to be an extreme fluke if all 4 of your injectors are clogged to the point that they aren't passing any fuel.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
seagull
Post by seagull » Thu Feb 16, 2006 12:04 am
even more if the one I selected to remove was not working !
I am not getting a bang on any cyl so not sure whats going on .
tim_81coupe
Post by tim_81coupe » Thu Feb 16, 2006 12:46 am
Simple silly question - is the starter motor -> ecu wire connected?
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
seagull
Post by seagull » Thu Feb 16, 2006 12:51 am
yes mate it is
motor is turning over ok no firing due to plugs not wet .
fuel in & out ok
seagull
Post by seagull » Thu Feb 16, 2006 2:05 am
yep I am lost to why this will not go Help !!!!!!!!!!!!!!
BlackMale
Post by BlackMale » Thu Feb 16, 2006 10:03 am
tim_81coupe wrote:Simple silly question ?
I have a few more of em...
Timing Belt on correct?
Plugs gap have been checked?
Getting air?
Lets not talk about compression (you are sure your getting any).
tim_81coupe
Post by tim_81coupe » Thu Feb 16, 2006 6:50 pm
I can come take a look either tomorrow night or some time on the weekend if you want seagull.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
seagull
Post by seagull » Fri Feb 17, 2006 1:17 am
Cheers Tim .I have it started now .
I dont realy know what the main issue was .as I did a few things at the same time .
I removed one of the injectors and ran the fuel pump * bad fuel in system * hold your nose !
I played with a few plugs at the same time , pulled them apart and back together .
then hit the key it came to life ! sweeeeet as
I also got the front stuts under it with the lift kit I made so happy boy here .a few mods to the shifter bracket I made an then see if the auto works .
Tim your welcome to come over I have very cold beer
cheers seagull
BlackMale
Post by BlackMale » Fri Feb 17, 2006 11:19 am
Just when i was on my way out there 2day as well... good to hear that she is running again.
seagull
Post by seagull » Sat Feb 18, 2006 1:25 am
I drunk the beer all by my self as well , with a grin on my face with it running in the shed !
:D
