Seals for Clutch LSD Diff
Fang
Post by Fang » Sat Oct 25, 2008 3:06 pm
I recently procured an LSD for my second L Series. The thing was covered in oil and dirt. Are they susceptible to leaking? Should I replace certain seals before just plopping it in?
discopotato03
Post by discopotato03 » Sat Oct 25, 2008 6:50 pm
The thing that will make those R series diffs leak a bit (assuming the seals ARE ok) is if the little breather gets blocked .
From memory all long nose R160/180/200 diffs use a solid as opposed to a collapsable pinion bearing spacer so it should be possible to remove the companion flage and renew the pinion seal .
Have looked in my genuine 87 WSM and yes the pinion spacer is solid/ tubular .
The side seals can be got at by removing the splined stubs and levering them out/drifting new ones in with something of just a slightly smaller diameter ie socket .
If you are not sure take it to a diff specialist with a photocopy of the exploded diff diagram .
Are you in Sydney ?
A .
Any Datsun Rally specialist could do it for you easily enough .
Post by AndrewT » Sat Oct 25, 2008 7:51 pm
Datsun rally specialist? pretty sure the work experience kid at just about any mechanics workshop could replace oil seals on a R160 diff :) It's likely to just be the side seals.
Fang
Post by Fang » Sun Oct 26, 2008 6:39 am
Adrian - I would not be suprised if the breather was blocked. It was caked in oil and dirt. The seals on the side don't seem hardened (thats not to say there isn't a problem)
I am in Brisbane. Not sure about giving it to a Datsun specialist - those guys may flog it :p
Post by El_Freddo » Sun Oct 26, 2008 10:36 am
Fang wrote:Not sure about giving it to a Datsun specialist - those guys may flog it :p
Yeah, you got yourself a good one by the sounds of it Fang! I'm about to weld a diff while I "wait" for an LSD to magically appear...
PeeJay
Post by PeeJay » Mon Oct 27, 2008 4:39 pm
Those side seals can be changed in about 15 mins if the diff is out of the car. I think my seals only cost $3 each so you're crazy not to do it.
Fang
Post by Fang » Mon Oct 27, 2008 5:52 pm
El_Freddo wrote:Yeah, you got yourself a good one by the sounds of it Fang! I'm about to weld a diff while I "wait" for an LSD to magically appear...
Hey Bennie - yeah I think I paid a bit too much for it but they are getting rarer than hen's teeth so I grabbed it while I could. It was from a wrecker as well - and they knew it was worth (unfortunately). Your locked diff will keep you honest though ;)
PeeJay wrote:Those side seals can be changed in about 15 mins if the diff is out of the car. I think my seals only cost $3 each so you're crazy not to do it.
Yeah agreed on that - certainly sounds worth doing.
T'subaru
Post by T'subaru » Sun Nov 02, 2008 4:17 am
Although I'm new to Sub-wheeling, I always mounted my diff and alxe breathers on my land cruisers and toyotas remotely via hose to keep them clear of water, mud etc.
Fang
Post by Fang » Sun Nov 02, 2008 6:29 am
subuaroodude wrote:Although I'm new to Sub-wheeling, I always mounted my diff and alxe breathers on my land cruisers and toyotas remotely via hose to keep them clear of water, mud etc.
Yup I have that done on my other L Series - and will be doing the same on this one too.
