more EJ conversion questions
yeah, ive been running a VL turbo fuel pump with carby fuel tank forever. Works fine! Just drill a small hole in your fuel cap so it can release pressure. Otherwise it will surge and play funny buggers.
I too have been using a high pressure EFI pump on the standard carbie tank without any problems with exception to the odd surge - hole in the cap may have helped if I had have received this info a few years ago...Keffa wrote:yeah, ive been running a VL turbo fuel pump with carby fuel tank forever. Works fine! Just drill a small hole in your fuel cap so it can release pressure. Otherwise it will surge and play funny buggers.
I know that feeling and my car's not even that far away from me!!! Its just nothing but time...GOD wrote:Now it's just a matter of getting away from uni here in Kal so I can go and work on the car in Perth.
If you have a surge tank between the EFI and the standard pump there's nothing to worry about in regards to the standard low pressure pump, if you have the standard pump and the EFI in line without a surge tank I'd def be ditching that low pressure (standard) pump!
Good thinking. My plan had the carby pump keeping the EFI pump primed, but that big EFI pump is probably trying to maintain a much higher flow rate than the little one, hence the surging.El_Freddo wrote: If you have a surge tank between the EFI and the standard pump there's nothing to worry about in regards to the standard low pressure pump, if you have the standard pump and the EFI in line without a surge tank I'd def be ditching that low pressure (standard) pump!
I wanna go and play with my car!
RedNekTJ wrote:What make/model did your efi tank come out of?
L series EFI and EFI turbo vehicles.
It wouldn't be a direct bolt in job, as to wether you could get one to fit, that'd be open to speculation without looking at a standard brumby tank and the EFI L tank...RedNekTJ wrote:Will they fit into a brumby?
it's alive!
A bit of an update:
Removed the lift pump, so fuel is coming out of the tank through the standard filter to the HP pump, and she goes!
It took a few jump starts before working out the alternator needs an earth wire in order to charge the battery. And does the other wire (white red?) for the L series alt idiot light plug straight onto the other terminal on the EJ alt?
One odd thing i've noticed is that whenever the back end is lifted with the trolley jack centred under the diff, the right wheel stays on the ground until the left is a good 30mm or so in the air. What should one look at to fix this - bushes?
Jobs left:
-get the EJ header pipe joined up to the original exhaust
-rejig seat rails - the Lib seats are great, but too high, and my head hits the roof.
-replace pod filter with a box
-replace damaged LHF door
-finish central locking
-rego!
Should be done and on the road within a few weeks.
Dane.
Jobs left:
-rego!
Dane.
