Auto no go
stamp_licker
Auto no go
Post by stamp_licker » Wed Oct 01, 2008 7:26 pm
Here's the deal.Driving along go to overtake a dangerous driver floor it get a good kickdown revs out dumps into gear all good.About 5Kms down the road auto starts slips back off manual shift no worries add a bit of load or throttle a wee bit of slipping,by the time a get to stop got no gears.Shut down the motor got to start it again lots of starter/TC spinning no motor spinning.Now you can spin the flex plate theres no resistance.
Now i'm thinking all the bolts in the flexplate have sheared or fallen out.Any ideas?
What do ya reckon:confused:Anyone had this happen ?Wouldn't think a ej22 would have bolt busting power.:twisted:
Building a hardcore postie:D
Matatak
Post by Matatak » Wed Oct 01, 2008 7:28 pm
sounds like ur Driveplate is broken.
theyre pretty thin really
i sold my old one to a guy with a Gen1 Sedan Auto whos broke onenight.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Captain Obvious
Post by Captain Obvious » Wed Oct 01, 2008 8:44 pm
yeah sounds like it could be the flex plate will!! only logical thing!!
riksta
Post by riksta » Wed Oct 01, 2008 9:07 pm
yeah it can happen Will, my brother had it happen to him in a comadore some years ago.
Rik.
vincentvega
Post by vincentvega » Wed Oct 01, 2008 9:22 pm
yeah you have done a flex plate mate. if the converter is spinning and the engine isnt its the only explanation...
i have seen a cracked one but it was behind an EJ20T. you must have done a top job rebuilding that thing ;)
Post by El_Freddo » Wed Oct 01, 2008 11:17 pm
vincentvega wrote:you must have done a top job rebuilding that thing ;)
Or giving it a good flogging!!
tex
Post by tex » Wed Oct 01, 2008 11:40 pm
Yeah I've torn a flex plate in two leaving a nice neat little circle around the flex plate bolts and thrust bearing (Not in a subaru though).
But before you tear the whole thing apart just check your transmission fluid with the engine running because if you've just blown a hose or run out of fluid this could save you some time and heart ache!
87 targa brumby (Neglected),
+ others.
Matatak
Post by Matatak » Thu Oct 02, 2008 12:20 am
tex wrote:Yeah I've torn a flex plate in two leaving a nice neat little circle around the flex plate bolts and thrust bearing (Not in a subaru though).
that doesnt explain the nocrank though...
stamp_licker
Post by stamp_licker » Thu Oct 02, 2008 5:09 am
definately seperation between crank and plate.You can spin the motor and see the rear turn and no movement at the plate.Guesss itss motor out or box slipped back to inspect the real damage.
vincentvega
Post by vincentvega » Thu Oct 02, 2008 9:02 am
you are skilled in the art of breaking that thing posty!
what flex plate was it?
stamp_licker
Post by stamp_licker » Thu Oct 02, 2008 3:11 pm
Just about to start pulling it apart.Flex plate i think is a gen 1 awd one,got a tt one and a rs one but they are different if i remmeber correctly.
Got any spares Dane?
Outback bloke
Post by Outback bloke » Thu Oct 02, 2008 4:20 pm
I might have one here. It is sitting on the rubbish to be thrown out this week end. I will dig it out for you.
yarney
Post by yarney » Thu Oct 02, 2008 5:21 pm
Will it's time for a manual box:rolleyes:
Jan
vincentvega
Post by vincentvega » Thu Oct 02, 2008 5:55 pm
hell no Jan!
vincentvega
Post by vincentvega » Thu Oct 02, 2008 5:56 pm
yeah there is a spare still bolted to my original box if your stuck..
stamp_licker
Post by stamp_licker » Thu Oct 02, 2008 7:37 pm
Outback bloke wrote:I might have one here. It is sitting on the rubbish to be thrown out this week end. I will dig it out for you.
Thanks Brett.Will call tomorrow
yarney wrote:Will it's time for a manual box:rolleyes:
Jan
If i go manual it wiil be behind a lifted impressa hatch:twisted::twisted::twisted:
vincentvega wrote:yeah there is a spare still bolted to my original box if your stuck..
Thanks Dane for the offer.
Haven't seperated it yet but am pulling the motor to do it and a few other things while its out,just a few bolts to go.The tc is unbolted from the flexplate and you can spin the flexplate around so its definately buggered.
A few metal filings in ther too.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Oct 02, 2008 8:31 pm
I have seen on some models a larger than normal plate that bolts over the back of the flex plate and is about 6in in diameter, my only thought would be to stop excessive flex causing the flex plate to shear.
The long road ahead
stamp_licker
Post by stamp_licker » Fri Oct 03, 2008 4:27 pm
Heres the carnarge,well not all of it.
The tally
One broken flexplate
chewed out spigot
chewed out locater on the t/c.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Oct 03, 2008 5:06 pm
Is the spigot in the rear of the crank damaged?
how badly chewed is the centre locator?
Made a nice neat cut out of the flex plate
The long road ahead
vincentvega
Post by vincentvega » Fri Oct 03, 2008 6:58 pm
fark thats impressive!
were the bolts all tight when you pulled the remains out?
Return to “Trouble Shooting”
