THANKS IN ADVANCE FOR ANY HELP.
does it happen when you push the clutch in?SUBANOOB wrote:MY 92 BRUMBY 4 SPD. EVERY TIME I CHANGE GEARS 1,2,3. THERE IS A HIGH PITCH WINDING NOISE. IT FIRST BEGAN WHEN I DROVE IT HARD....SILLY, I KNOW. IT IS A VERY WEIRD NOISE, ALMOST LIKE......THIS SOUNDS STUPID, LIKE A SUPER CHARGER UNDER THE HOOD.
Yeah thats right. It might be worthwhile replace the clutch while the box is removed, saves headache later. Otherwise you can just replace the bearing itself. If it was me i'll buy clutch kit and replace whole kit.Suba wrote:Thrust bearing , pull the box out and replace the thrust bearing , cheap and relitivly easy job.
Mike.
That's all the doughies you were doing in the mud:twisted:SUBANOOB wrote:MY 92 BRUMBY 4 SPD. EVERY TIME I CHANGE GEARS 1,2,3. THERE IS A HIGH PITCH WINDING NOISE. IT FIRST BEGAN WHEN I DROVE IT HARD....SILLY, I KNOW. IT IS A VERY WEIRD NOISE, ALMOST LIKE......THIS SOUNDS STUPID, LIKE A SUPER CHARGER UNDER THE HOOD.
