Clutch Problems
ChPLAT
Clutch Problems
Post by ChPLAT » Sun Aug 17, 2008 5:18 pm
Been noticing lately that when I have the clutch in, even before it gets anywhere near full travel, it has a bit of a squeal. Nothing too bad but still something to worry about?
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
chubby37
Post by chubby37 » Sun Aug 17, 2008 6:02 pm
throw out bearing...not exspensive but need to pull box or motor out to fix it....lees performance at springwood can get them if you cant find one
Post by AlpineRaven » Sun Aug 17, 2008 7:14 pm
Gotta get that done soon before it screws up big time then you wont be able to change gears!.. (happened to me in Bendigo and had to drive to Geelong with stuffed up clutch and had to crash gears..
ChPLAT
Post by ChPLAT » Sun Aug 17, 2008 7:15 pm
Ok then I'll look into it ASAP. Cheers guys.
Past rides-
1989 Brumby
Current ride-
chubby37
Post by chubby37 » Sun Aug 17, 2008 7:19 pm
easy way to do it is lift the motor up but not all the way out and you can just slip one bearing out and the new one in....
Post by AlpineRaven » Sun Aug 17, 2008 9:09 pm
Actually... how old is the clutch? Does it have much wear left? Wouldn't it be easier if change the clutch assembly instead of doing the bearing alone? Just a thought.
ChPLAT
Post by ChPLAT » Sun Aug 17, 2008 9:13 pm
I'd say its the stock clutch as its only done 130.000.
Past rides-
1989 Brumby
Current ride-
chubby37
Post by chubby37 » Sun Aug 17, 2008 9:42 pm
if you replace the clutch there are 2 sizes...pull it out and measure it so you get the right one....it cought me out once doing a a mates my
