Sounds good but I am on the other side of the country - but if you could get some photos would be great. Would like to know if he is using EA or EJ tye gearbox though.khanacross wrote:there is a brumby in newcastle area with rotary fitted,, goes well apparently ,dont know full details of it ,,,friend of a friend owns it ,,,pm me for his contact details ,,maybe can line up a viewing .... fingers crossed
Brumby build with a difference
I'm hoping the lack of torque and the high revs will actually give the box an easier time - especially with my mechanically sympathetiic driving style.spike wrote:so basically you need racing rotary in a racing subaru
The 6 speed is definatly the way to go, even if people are breaking them with the eg33 turbos
Although an 8000rpm side step off the clutch for a drag launch will probably kill any Subie box
- subybrumby
These guys have got one http://www.facebook.com/album.php?aid=1 ... 8649057608
Doesn't look like it is 4WD any more thoughsubybrumby wrote:These guys have got one http://www.facebook.com/album.php?aid=1 ... 8649057608
only thing ive ever seen kill a 6 speed was SVX twin turbo drag car, think it was close to 10 grand revs, side step, dug in. clunk, splat, tearsniterida wrote:Although an 8000rpm side step off the clutch for a drag launch will probably kill any Subie box
the rotary engines make perfect sense to me, its piston engines that confuse me
UP, STOP, DOWN,STOP, UP, STOP ETC
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
rotormotion are rotary tuners and just around the corner from me. in the morning and early some evenings the sound of 1000 wild victa lawnmowers straining against the dyno drifts over the languid air. it is music, sweet music.
sometimes they test them on the quiet backstreets and the screaming of the lackybands plus the acrid stench of burning rubber fills the air.
mmm! for a lackyband. good luck
"UNDERSTEER" is when you hit the fence with the front of the car.
"OVERSTEER" is when you hit the fence with the rear of the car.
"HORSEPOWER" is how fast you hit the fence.
"TORQUE" is how far you take the fence with you.
If it works, pull it apart to see why.- TOONGA
something like this sitting in the engine bay would look nice.....
.....actually it would more likely be a brumby strapped to the engine but hey
http://freepages.family.rootsweb.ancest ... 9,r:3,s:24This 28-cylinder air-cooled engine displaced 4,360 cubic inches and produced 3,800 horsepower. The B36 had six of these each driving a large propeller plus four seperate outboard jet engines.
Hahaha - I will ask him for youniterida wrote: If your dad is looking for a car to test his engine I will gladly let him use mine as long as I get to keep an engine afterwards and as long as it puts out 1000hp hahahaha
Giles.
Giles.
Good question dibs - they do not create much vacuum - we had issues installing an aftermarket cruise control unit, turned out that to make it work we had to cut a set wire on the CC unit to accept low vacuum pressures. Once this was done our CC worked a treat. That rotary was awesome too!dibs wrote:dumb or not do rotarys creat much vacuum .im thinking vacuum pump
Dad's loved them (and V8's) for a long time. His mkII fastback VW had a 13B rotary in it reversed 180 degrees. The only reason its not going now is that it doesn't have a rotary to go in it and dad doesn't have the time sort it out if he did
The series 2 RX7 which the CC went into was a great unit - other than it was a 3 speed auto, although you could drop it into 2nd at 90km/h and it would scream off without as much as a hesitation. We hit the buzzer numerous times
yeah I still own the Leone Coupe with the 13bt in it and yes it's the one on youtube. And yes it's a rotary despite what the YouTube peanut gallery say.
It's a series 5 13b turbo with adaptor plate running a liberty 5 spd awd box, wrx rear diff and four wheel discs.
For all the poo hooing, it's a crap load of fun and sure they swallow heaps of petrol and oil but you're not putting a rotary in for fuel economy or you'd stick with the ea81 and the hitachi carb!
Keep it tuned, do your oil and plugs regularly and GET A VERY GOOD CLUTCH!
Stick to your original plan - Subaru AWD.
Giles.
Giles.
