Guards
subusurfer
Guards
Post by subusurfer » Mon Jul 16, 2007 1:50 pm
Gday, does anyone know where i can source some black plastic inserts which go over the guards, in adelaide?
Post by Alex » Mon Jul 16, 2007 2:41 pm
do you mean spats or guard flares?
Jeff
Post by Jeff » Mon Jul 16, 2007 4:04 pm
Subawreck on Main North Road
subusurfer
Post by subusurfer » Mon Jul 16, 2007 11:02 pm
not really sure what they are called, just looking for the black plastic (i guess u call them flares) which sit over the wheel arch.
Bratgeebah
Post by Bratgeebah » Tue Jul 17, 2007 7:59 am
Clark rubber. Two different profiles available. They sell it by the meter.
Learner
Post by Learner » Tue Jul 17, 2007 8:40 am
how does it work if they sell it by the mter? isn't it molded? isn't it soposed to extend the width of the arc for legal issue with larger tires?
1989 L touring wagon auto (project)
1969 beetle street car (project)
= me:) :D
Bratgeebah
Post by Bratgeebah » Tue Jul 17, 2007 9:03 am
It's an extruded, flat (with a profile on its cross section) wide(about 2"
two widths available) strip of black rubber (flexible on its length) that you cut to length and place around the wheel arch. You see it alot on old Landcruisers and Patrols etc. and I've seen it on a few Subarus on these forums.
fredsub
Post by fredsub » Tue Jul 17, 2007 9:47 am
4wd outlets sell it. It comes with a 1.5mm wire which is pushed thru/along the rubber, hence it holds its shape very well. I've seen the clark rubber stuff,buts its not made the same i don't think.
Yes I used it, as the desert rats do have a wider stance (offset) not just bigger tyres.
comes in 2 widths, you'll want the shorter, um 38mm?
The Scoobyside
Post by The Scoobyside » Sun Dec 09, 2007 9:07 pm
G'day
Are the rubber flares from Clark rubber fitted by drilling it to the bottom of the wheel arch?
If not, how are they attached?
