5 Stud Conversion
Matatak
5 Stud Conversion
Post by Matatak » Mon May 28, 2007 10:12 pm
can anyone tell me where to get kits to convert my subi from 4 stud to 5 stud if at all possible
or atleast prices becuase im still not sure if i want to do it
bluesteel
Post by bluesteel » Mon May 28, 2007 10:21 pm
http://www.crossbredperformance.com/
it is bratgeebah on these forums
stiute
Post by stiute » Fri Jun 22, 2007 12:29 am
As said above, contact Gareth at crossbred performance. He is a great bloke, more than willing to help fellow subaru owners. I have one of his kits and it is one of the best mods you could possibly do to your subaru!
90brumby
Post by 90brumby » Fri Jun 22, 2007 12:33 am
em the monster wagon (andrews car) is gettin 1 of them fitted
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Cam
Post by Cam » Mon Jul 02, 2007 5:09 pm
They kinda costly for what you get tho, i guess not a huge market.
Can the rear drums off an early impreza be put on some how?
Ben
Post by Ben » Mon Jul 02, 2007 6:26 pm
Cam wrote:They kinda costly for what you get tho, i guess not a huge market.
You think?
Try getting brand new brake upgrades of this calibre for other models, I think you'll soon change your mind...
As for the second question, this could be achieved using the Crossbred kit, which discs are a far better option.
Please watch before posting!
chriSTIan
Post by chriSTIan » Mon Jul 02, 2007 9:16 pm
Or you could go this way,cheaper but illegal.
These are 15/6 rs turbo wheels with 205/60 tyres
Post by El_Freddo » Mon Jul 02, 2007 9:24 pm
what's wrong with re-machining the hubs for the 5 stud subaru pattern? Is this also illegal?
And those RS rims look sweet on the L ;)
Post by steptoe » Mon Jul 02, 2007 9:55 pm
Had to look twice, thought i was lookin' at a Liberty and wondered what was so special.
chriSTIan
Post by chriSTIan » Thu Jul 05, 2007 9:22 pm
Re rilling hubs to 5 stud is a problem because of the ribs on the hubs and drums(i think)
Now with 70's series tyres
Chris_Rogers
Post by Chris_Rogers » Thu Jul 05, 2007 10:09 pm
its a lot of fiddling to do. I have done it and I'm still mixing and matching things.
brats kit is the easy way of doing it. I spent $2k on the rear of mine alone doing it. reworking the impreza stuff and new lines etc was the worst part of it. I have XT6 hubs on mine that I imported from the USA ($550) for a bolt on swap. brats hubs are a DIRECT copy of them that he designed and engineered himself. (we compared them when I was in MLB last year.)
the impreza idea isn't legal as it machines the hub down and weakens it.
to do what you want you need:
front:
steering knuckle swapped
lower ball joint needs swapping and the lower control arm modded to take it
mix N match of axles.
legacy struts
rear: impreza brake assy complete. handbrake cables, 5 stud hubs, impreza handbrake or similar (looked at a diahatsu charade one looks like it would bolt in.) and a lot of fiddling/time ;)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
90brumby
Post by 90brumby » Thu Jul 05, 2007 10:52 pm
chriSTIan wrote:Or you could go this way,cheaper but illegal.
is this just a xta hub that bolts on to somethin
is there more info on this
tristan
chriSTIan
Post by chriSTIan » Fri Jul 06, 2007 10:28 pm
No 90brumby
I got these made a while back in Perth.
I have 1 spare as a tempate.
From memory they cost me $100 ea not including studs
Then you have to machine the hubs/drums flat to suit.
Also got a locating lip cut in them,safer.
Remember,they are illegal,use at your own peril.
(tested them out in Lancelin dunes a while back)
90brumby
Post by 90brumby » Sat Jul 07, 2007 1:55 am
dam double post see below
90brumby
Post by 90brumby » Sat Jul 07, 2007 1:56 am
mate was not illegal with my car
legalaties are not a issue with me if it can b put bak to standrad if need b
wats the chance i can use ur templae
brumbyrunner
Post by brumbyrunner » Sat Jul 07, 2007 6:45 am
If you use a 4-stud to 5-stud adapter you can bolt on some 5-stud rims.
With the Crossbred kit you also get to use the bigger brakes from Libertys & WRXs.
Something to think about if you want to run bigger tyres or have more horsepower.
chriSTIan
Post by chriSTIan » Sun Jul 08, 2007 10:55 am
Yes correct.
I have used std rear drums and rear discs with my adaptors,to me it was the easiest way to fit 5 stud wheels.
The cars had stock power so no issues with bigger brakes for me.
Fury
Post by Fury » Tue Jul 17, 2007 9:12 am
I also have one of the kits, - which by the way is the best and easiest legal way to go.
I also looked at redrilling the "L" series hub, and purchased a pair of 4x 114.3 hubs, only to be told by an engineer that unless it conformed to either an Australian standard, or modded by a licenced engineer shop ( or someone who has qualifications on paper) can supply a metalergy certificate and documented welding certificate, that it will not conform. Any stud hole that is left unwelded, within 22 mm of the new stud must be welded with apppropriate material ( 40 41 alloy I believe) heated, welded, heated again and slow cooled so the surrounding material is not compramised.
just the metalergy conformation cert was going to be $250 ! quote on welding 4 hubs, machining and redrilling the hubs and new studs was approx $120 each
... and you are still left with small brakes and an engineers certificate to organise.
Gareth's kit is a fair price for the work that has gone into it, will help as much as he can and has no faults that I can find. Mine has been of for about 10 months - a few weeks before the 06 BBQ -
If you are doing the 5 stud thing, this really is the way to go - even though it "seems" a bit more costly than we would have liked, as I too was financially strapped at the time.
At least consider it. By the way, the engineer that I went to had a look at the kit, said it looked like OEM stuff and if involved in a colission, requiring a tear down, that it probabaly wouldn't even be noticed. - as opposed to spacers, redrilling that would.
Chris :cool:
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT! ;)
