Gonna need some help w this one....
L series wagon, 3" lift. Where transmission cross-member left front Block joins the body, block and member ok but body busted (see pic). Also floor/under body just above where the block meets the body is all buckled too. Looking at the damage there isn't too much fresh metal marks, so I'd say its been breaking over time and just gave in now.
So how should it be fixed, and whats involved? Jack the engine up and disconnect the cross member, get it out of the way and weld in a larger bracket/patch piece of metal, bolting it to the body then the fit the lift block to it???
I'm not a welder by any means and don't have any equipment. I guess it won't pass rego either....
Bit of a spot weld here might do the trick
This one might need a little more than spott welding...
Any way all advice is welcome.
Smokey
