Disc brake rear ends
Great thread from Toonga re the L series disc brake conversion but do the Leone rear ends go across to the Brumby's or only the L series and or Vortex
From what I've heard, they bolt straight across onto the Brumby/MY
Best way to check would be to get the drum brake backing plate off an L series (cos 99% of them have this & they're worth next to nothing), and see if it bolts onto an MY.
If that works, then the disc brake rear end will too because thats a direct bolt on replacement for the L series.
If you do the rear brake conversion, then you should also upgrade the fronts to L series spec. There's no difference between NA/turbo on the fronts.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
MY series and L.Series have the same bolt up pattern for the backing plates, whether their drum or disc. If you're converting from drum to disc, you'll need to grab everything from the disc setup, i.e. brake line hoses, bolts, clips, etc.. I would suggest you remove all of the drum parts and throw them in a box and once you have the disc fitted and working correctly.. just throw that box away
Oh.. if it's the rear K-frame from the L in to the MY then the answer is no. Why would you bother? The MY has the adjustable torsion bar as opposed to the L
Only thing the MY needs is sway bar mountings, which can be welded on quite easierly.
The other thing you need to be really specific about is the hub for the disc to mount on - the 2wd is different to the 4wd unit, this is the only difference in the rear disc setups for the 2 vs 4wd
On a side note, L series self adjusting drum brakes can be swapped onto the MY's but you need the L series backing plate and drums as well
- Silverbullet
Ah! Thanks Bennie! I've all but given up on finding a rear disc setup along with some Scorpion rims but the L series self adjusters will be better than the manual MY ones. Hopefully with braided lines, L or Lib brake booster and serviced master cylinder rear drums could be bearableEl_Freddo wrote:On a side note, L series self adjusting drum brakes can be swapped onto the MY's but you need the L series backing plate and drums as well
