EA81 on LPG
smiles
EA81 on LPG
Post by smiles » Mon Feb 01, 2010 4:15 am
Hi Everyone,
I'm considering converting my 92 Brumby to a dual fuel system. Are there any modifications I should do before I take it in to the LPG shop, to optimize the final outcome- like fitting a different carbie, or air box?
Also has anyone managed to fit a tank under the forward end of the tray? There is a fair bit of room there..
Cheers.
Post by AlpineRaven » Mon Feb 01, 2010 6:57 am
There is a few people converting to gas behind EA81, The Brumby Ive seen in the past (a few) has a tank in the tray, I agree there is a fair space under it as well.
Post by steptoe » Mon Feb 01, 2010 8:16 am
Done two Brumby EA81 to LPG straight. Tailshaft gets in the way of under tray instal of tank. It'd be a pain to fit two small tanks up there. I fitted tank at front on tray.
Really, you need to talk to installer coz things depend on what system he has in mind.
I went Impco 125 mixer, Impco J or cobra converter.
One has VN air box where jack was. A universal steering rack boot then feeds filtered air to the bell mouth of a side mounted mixer mounted to where the AC compressor was, then a custom made exhaust pipe joined to a mandrel bend with silicone hose onto a box of 100 x 50mm steel RHS with welded up ends. This box sits atop my twin Hitachis using extended hold down studs from carby up through box to hole and nut washer arrangement.
The other is Mitsu efi TB adapted onto EA81 manifold and mixer sits on that joined with sili hose. Not happiest with it yet.
Impco now do a positive pressure J or cobra converter and spud mixer - may be best Impco set up to play with. Your fitter may have his own preference.
To mod the mech advance on the dizzy is easy too. Lift it off , braze up the outer ends of slots and file to suit ensuring Max total advance of 28 degrees
smiles
Post by smiles » Wed Feb 03, 2010 10:24 pm
There's plenty of options to choose from then. I just started a job that's about 40kms away so I'm going to have to get this done for sure. Thanks for your help. Another reason hang on to my Subaru is the excellent support on this forum!
justincase41
Post by justincase41 » Wed Feb 03, 2010 11:06 pm
40km, is that all. I'm doing 197km...... Ok just sold the brumby but have another in storage sizzling for an ej conversion but its going to have to wait until the mega garage is approved and built............
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
