Blow off Valves on turbo motors
wrx_nut
Post by wrx_nut » Wed Feb 01, 2006 5:27 pm
how much boost can you put on a ea82t without damaging it?
with the standard turbo?
PeeJay
Post by PeeJay » Wed Feb 01, 2006 7:02 pm
I had about 13psi on mine.
Pete
Post by Pete » Wed Feb 01, 2006 9:20 pm
In my previous Brumby I was running LPG only and an Air / Water intercooler. For tyre / CV life I ran factory (6 PSI ? ) as a daily driver. When silliness was required I ran it around 16 PSI up to 20 PSI and one accidental deviation up to 24 I think :oops:
It always seemed to run out of puff around 5000 RPM. Anybody with a theory on that one ? I did once put the tacho needle on the OTHER side of the red line with a jammed throttle cable 8O it actually took a long time to get there, a couple of seconds before I twigged and killed the ignition
I ran it like that for 2 years or so without a hiccup. I never noticed any pinging but then I was more worried about manifold pressures and keeping the thing going in a straight line.
wrx_nut
Post by wrx_nut » Thu Feb 02, 2006 4:37 pm
was that with a ea82t with a stock turbo?
Pete
Post by Pete » Thu Feb 02, 2006 4:43 pm
Fairly sure it was the stock turbo.
wrx_nut
Post by wrx_nut » Thu Feb 02, 2006 6:24 pm
did you bypass the wastegate with a a/m boost controller?
