question on EA82T into MY
TW83
Post by TW83 » Sat Aug 12, 2006 1:20 pm
Huh, not sure what you are talking about?
KERAZY
Post by KERAZY » Sat Aug 12, 2006 7:52 pm
isnt the MY brumby FT 4wd? im talkin about using all the stuff from that, and using the liberty shafts to fit into the EJ20.
TW83
Post by TW83 » Sat Aug 12, 2006 9:13 pm
(isnt the MY brumby FT 4wd? im talkin about using all the stuff from that, and using the liberty shafts to fit into the EJ20.) quote
Don't think it has full time 4WD, most have selectable 4WD.
The driveshafts don't go to the engine, they go to the gearbox.
You can use the standard drive train if you make an adapter,but there is no way this option will survive the increase in power
Hope that helped
KERAZY
Post by KERAZY » Mon Aug 14, 2006 9:37 pm
right. duely noted (spose).
if i wanted AWD (FT4wd) in my MY, with an EJ20G, probably lowered (not lifted, duh), what would need to happen?
could i have AWD with my EA81 at present?
KERAZY
Post by KERAZY » Fri Aug 18, 2006 1:42 pm
overlooked again?
TW83
Post by TW83 » Fri Aug 18, 2006 4:55 pm
Ej gearbox with the previously mentioned custom driveshafts or L stub axles. Custom gearbox crossmember, swaybar off a an auto MY (hopefully) or a modified one, lengthened tailshaft, modified gear linkages.
tim_81coupe
Post by tim_81coupe » Fri Aug 18, 2006 7:15 pm
There are 5 speed EA82 fulltime boxes, they are very rare though. These would bolt to the EA81 using the EA82 clutch and flywheel.
EA and EJ gearboxes really aren't hugely interchangeable. An EA motor running an EJ gearbox is something I've not ever heard of. A lot of guys run the EA82 gearboxes with EJ motors, but this usually results in too weak a clutch combo for the EJ turbo motors.
Ultimately if your aim is for a lowered EJ20G powered MY wagon you should save and do the whole Legacy RS engine / gearbox conversion in one hit rather than half / halving it.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
KERAZY
Post by KERAZY » Fri Aug 18, 2006 7:56 pm
think i should keep it front wheel drive?
tim_81coupe
Post by tim_81coupe » Fri Aug 18, 2006 8:37 pm
Not if you put the EJ donk in! Unless of course you like torque steer! :D
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
KERAZY
Post by KERAZY » Fri Aug 18, 2006 10:17 pm
not sure i would... but preeeety sure i like tyre smoke :D if i kept it PT 4wd and just had fwd all the other time, would i actually be able to get traction to the front wheels?
tim_81coupe
Post by tim_81coupe » Sat Aug 19, 2006 1:59 am
You really do want a fulltime AWD EJ box behind an EJ20G. I have my doubts that the part time box would stand up to the motor for a long time, and the part time boxes really are more suited to offroaders.
Tyre smoke is fun, there's no doubt about that. Problem is, driving a Subaru you're either going to get it from the wrong wheels or not at all.
A part time box in 2WD is as good as a FWD box as far as traction is concerned. Torque steer isn't fun and you'd probably find the car would spit axles and crack the transmission casing if you were putting serious power through it....
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
KERAZY
Post by KERAZY » Sat Aug 19, 2006 4:32 am
ahh ok. so basically, whats needed is an EJ20G from a lib RS, custom cv's, the liberty gb, custom tailshaft (l-series fits dont it?) and.... what else? sorry for the gay little questions, i wanna be real certain what i need to get and do if you can dig it.
tim_81coupe
Post by tim_81coupe » Sat Aug 19, 2006 3:04 pm
Best option is of course to buy a complete front cut as you'll get everything you need including all the little bits.
Basically you'll need:
Engine
Wiring Loom, Computer and all sensors/switches
Gearbox
Liberty inner CV joints (these mate to 2WD MY axles too, so you may be up for a pair of them)
Hydraulic clutch system
There would be additional costs over and above a front cut in the conversion. These would include:
Custom Tailshaft (120mm longer than 4wd MY)
Fuel system, this includes pump (we usually use bosch 070 VL pump) surge tank and new high pressure lines
Radiator, go twin core with MY tanks and enlarged outlets. On a stock height car you'll want the outlets pointed towards the motor's inlets
There's a lot more to it when you get to the building stage, remember you need the subframe mods, firewall mods (for the clutch), clutch pedal mod, custom gearbox crossmember, custom linkage shortening, the list goes on.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
KERAZY
Post by KERAZY » Sat Aug 19, 2006 5:46 pm
righto. so 4 or 5 grand thereabouts just for the stuff, bout 12 grand to get someone to do it that has done it before?
