EJ20 into l series
drof351
EJ20 into l series
Post by drof351 » Fri Nov 27, 2009 11:18 pm
Hi is there anyone in perth who can help me cut down the ej harness to suit my l series? Thanks
RST-20
Post by RST-20 » Sat Nov 28, 2009 9:39 am
Give Doug a ring 0427 532226.
He will know of somebody in WA
Checkers
Post by Checkers » Sat Nov 28, 2009 9:40 am
Or you can just ship it to AM Autos in Yandina and Al will do it and ship it back.
maxxair
yeah.
Post by maxxair » Sat Nov 28, 2009 1:09 pm
its pretty simple, once you have the wiring diagram.
Cheers, Rohan M.
drof351
Post by drof351 » Sat Nov 28, 2009 7:51 pm
Thanks for the reply guys. I'm on a pretty tight schedule and don't have the right wiring diagrams etc. The engine and gearbox are in the L series, it's running with harness resting on the rad support. I'm getting the L series shafts re-splined to suit the 98 model cv's and still messing around with the shifter but getting there.
Post by AndrewT » Sun Nov 29, 2009 10:00 am
Hi mate. Give Subarino a PM, he might be interested in doing a loom for you although he mostly only does EJ22 ones. Worth a try tho.
Re-splining the shafts? that's abit weird I've never heard of that being required. Sounds expensive. What gearbox are u putting in?
drof351
Post by drof351 » Sun Nov 29, 2009 10:38 am
The AWD auto that came with the 98 wagon i bought? The L series shafts are thicker. Thanks
Post by AndrewT » Sun Nov 29, 2009 5:55 pm
what kind of inner CV's does the gearbox need? are they the male type which "plug in" to the female part on the gearbox?
drof351
Post by drof351 » Sun Nov 29, 2009 6:27 pm
The ej gearbox has the shafts sticking out and the cv slides over it held on by a roll pin?
Post by AndrewT » Sun Nov 29, 2009 7:30 pm
yep sounds like we got to the bottom of it in the other thread there :)
drof351
Post by drof351 » Tue Dec 01, 2009 8:32 am
What do I need to do with the diff? It's a later model one with the cv's that go into the gear box.
Post by AndrewT » Tue Dec 01, 2009 10:20 am
Gearbox? U mean diff maybe?
I think you might mean it's a later model diff with female inputs on either side, ie it had male inner CV's in it's original car.
If this is the case I havn't put one of those in an L series before and am not 100% sure on the solution. I think there is an inner CV from some donor car which will go onto your L series rear shafts.......but it's much much easier to get a rear diff with male stubs and stick that in. Just need to be sure it's the correct ratio.
What ratio is the diff you have, and is it LSD of any kind?
Post by El_Freddo » Tue Dec 01, 2009 4:08 pm
AndrewT wrote:Gearbox? U mean diff maybe?
Would it be possible to do the centre swap trick to have a diff centre that has the male stubs bolt to it? Thus creating a male stubbed rear diff.
The other trick I've heard is to grab another set of rear diff stubs, grind a groove in the same place as the impreza's rear driveshaft to fit the retailing pin in. Plug the bolt hole with some silicone then tap them into place. Hopefully some one can verify this trick ;)
drof351
Post by drof351 » Sun Dec 06, 2009 12:54 am
Hi has anyone got the wiring diagrams to suit the 98 impreza sportswagon ej20 awd auto? Thanks
