MY GLF dash in MY DL
- tim_81coupe
I know this was talked about on the old forums, just searched here and I can't find anything on it.
I've now decided to wreck my beloved coupe despite the strong support for keeping it, sorry. I'm thinking about transplanting the GLF dash into my wagon, amongst other things, and I want to know how difficult it will be. I'm assuming at the moment it will be too much trouble but I thought I'd ask first.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Buy a touring wagon... it's easier.
Dave
Dave
- tim_81coupe
dash
Sorry to hear your having to end the life of the narly coupe ..
But thats life
The dash could be a plug and go ..subi like a lot of manufactors multi plugged there harnesses to do model changes.
But thats life
Use The Fork Luke
- Ben
There was year to year changes so may require some cut/shut of the wiring in the dash. My very first sube copped a 82GLF dash and was an 83 Sportswagon itself. Everything ended up working except for one weird little problem that the windscreen wipers would only work when the headlights were on - kinda like a built in safety feature
- tim_81coupe
So was it mostly plug and play? Not that I'm scared of a bit of soldering / cutting and shutting, just weighing up my options.
It's an 82 GLF5 and an 82 DL, so hopefully there aren't a heap of differences. I will have to get a wiper switch off a Touring Wagon, as I want intermittent wipers as well as a rear wiper.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- tim_81coupe
- Outback bloke
MY-STI just swapped mine for me, it's do-able, you will need some 90 degree phillips head screwdrivers to do it with the windscreen in.
1989 Subaru WonderBrumby II
I have done it also Tim.... without removing the windscreen. It's not much fun though.
Dave
Dave
I converted the digital dash to analogue 6 gauge dash. The car was an 83' coupe with digital dash and the other 6 gauges came from an 82' coupe. Luckily I kept the looms in dash and the engine bay. Wiring and parts different relating to blinkers/hazard and the headlights between the 2 models.
Headlight relay located next to fuseable links in 82' model and next to fuse box in the 83' model.
Blinker and hazard lights 82' model uses 2 flasher units and the 83' model has one unit for both.
Needed the back loom for the blinkers but have sorted it out to work temporarily.
