HID install Hi & Lo - confused...
Post by AlpineRaven » Fri Jul 25, 2008 9:52 pm
G'day,
I have HID kit here plugged it in, it works but full beam & HID is on together at low beam, if I flick on full beam HID goes out but full beam, HID goes funny as it'll flick on and off with full beam at the same time - looks like the priority is incorrect...
I checked out with multimedia, at full beam (looking at the female plug) its showing negative with top pin is positive, right pin is showing no power.
On low beam, left pin is showing positive with top pin is negative and left pin is postive... that is where the HID gets confused...
Get my drift? Is there correct way or switch to use HIDs?
bobbyjimmy
Post by bobbyjimmy » Sat Jul 26, 2008 9:13 am
Probably not your kit, but some good info here that may help;
http://wiki.seloc.org/a/Hurricane_HID_kit_FAQ
Without seeing anything/knowing you, and as it says in the above, i'd be leaning towards a dodgy ballast.
Maybe this also;
http://www.oznium.com/forum/topic10648
Post by AlpineRaven » Sat Jul 26, 2008 10:16 am
Yep I got it worked out, Have to separate the negative wires because it was causing conflict.
foxx510
Post by foxx510 » Sat Jul 26, 2008 3:21 pm
You might have to run relays and change it to positive switching, perhaps, as Subaru use negative switching as standard.
Post by El_Freddo » Sat Jul 26, 2008 7:44 pm
foxx510 wrote:You might have to run relays and change it to positive switching, perhaps, as Subaru use negative switching as standard.
After the MY's - not that this is a problem for AP, but for other's reading with this change in mind and own an MY could be good info
End hijack.
I hope to see these suckers on the 9th ;) We'll try and find a mud hole and see what's in there :p 8)
Post by D3V1L » Sat Jul 26, 2008 11:11 pm
i had this issue...have to keep the several wires seperate or they conflict with each other and cause issues
dave
