rs wiring ??
rs wiring ??
hey guys im just wondering if i can drop the rs harness and ecu in my 92 gx lib and will it run the auto box ? or can i do something to make it run the auto box?
cheers james
cheers james
Is the RS wiring loom from an auto 1/2 cut? if so then you souldn't have any troubles if you put the whole loom in and I'd use the RS auto TCU
I would try and swap your wiring loom for an auto one, will make you're life a lot easier.
thanks for replys guys
only wanna use the auto as dont have funds to buy a manual conversion at the moment and this motor is only temporarily as i have a ver5 wrx ej20t just gotta wait for the funds for wiring and manual conversion.
just wanted to put the rs motor in for a month or so.
so could i use my original gx auto wiring to run the rs ?
Do you mean.. use the EJ22 NA harness to run the EJ20T engine? if so then the answer is no. Completely different setup. I'm sure there is plenty of guys (on RS Liberty Club) that would have an auto loom that would be happy to sell or swap with you but if you're looking to change to manual later on then I'd wait and do the change all at once, otherwise you're going to end up buying lots of Nurofen
