Gearbox/ Diff Oil, "98 Forester
Does anyone know what gearbox oil I should use in my '98 Forester 5spd DR?
Since I got it about 6mths ago I have had big problems with it crunching gears & when its cold sometimes it refuses to go into 2nd. Even when hot it wont go into 1st unless completely stationary.
The oil is at the right level & clear (slightly yellow but clear, if you know what I mean).
I know there's all sorts of tricks you can do to help the synchro, like additives, better oil, etc. Someone somewhere mentioned red stuff...
What can I do to get the synchro working properly?
Also I will put in a diff breather sometime, & I'll do the diff oil at the same time. What should I use for that?
I use Castrol Multitrax 90w90 I think it is. Seemed to shift better after putting it in. I almost never have crunching except for my 1st gear which is pretty stuffed (teeth chipped). I can't go into 1st unless comepletely stopped also.
Redline lightweight gear oil is really good also but very expensive (something llike $200 for 5l here where I live). I haven't used it but will probably put it in when I do my g/b oil next.
Thanks Taza. $200 for the redline is waaay beyond my budget
Has anyone heard of putting a little Auto fluid in the oil? Apparently it has better shock resistance but I dont want to experiment with Ozzie's box lol
Steptoe, have heard smurf blood is as rare as hen's teeth
OK, thinking back to AU Falcon manual boxes. Fords supplier BTR Nylex specified an additive each time box oil replaced. Car goes in for routine service including oil change for box, goes to crap. Lots of research leading back to BTR finds said info, turns out dealer does not even stock the additive (so must have beena lot of cranky manual box drivers out there) customer had to teach the service advisor a thing or two (again) , get 'em to order it in and add it - fixed.
Wonder if this is same case - an add pack not used last change?
Guess why you are doin' research now .....
Rally uses Multitrax in his foz also I think. Im happy with it but you could always add a additive ontop if you want. I use a oil additive for my engine oil to try and help with the burning (500ml every 500km) but it doesn't make much difference if any. I think the Multitrax is about $60nachaluva wrote:Thanks Taza. $200 for the redline is waaay beyond my budget
- TOONGA
a small amount of transmission fluid won't hurt the box but there are better additives out there.
I use ICT M-10 friction modifier, it is made by Industrial chemical Technologies In Australia ( Morley WA) 1 litre cost 33 dollars when I last bought it.
http://ictproducts.net/product_informat ... ifier.html
It works great.
It works great.
Seems like Multitrax is the way to go.taza wrote:Rally uses Multitrax in his foz also I think. Im happy with it but you could always add a additive ontop if you want. I use a oil additive for my engine oil to try and help with the burning (500ml every 500km) but it doesn't make much difference if any. I think the Multitrax is about $60
Their website says not to use in LSDs. The Foz has a vLSD centre diff. I'll try giving em a call tomorow.TOONGA wrote:a small amount of transmission fluid won't hurt the box but there are better additives out there.
It works great.
Its pretty expensive but if it works I'll be happy
For standard (non turbo) boxes I use Castrol VMX.. this is a thinner oil designed for hard to shift boxes. I would however recommend it changed at 1/2 the normal service intervals.
Redline Lightweight Shockproof (or I like to call Smurf Blood because it goes an awesome blue colour when agitated) is primarily used in turbo boxes because of extra stress loads.
steptoe wrote:someone said smurf blood.....
Oh, now I get it lolRSR 555 wrote:For standard (non turbo) boxes I use Castrol VMX.. this is a thinner oil designed for hard to shift boxes. I would however recommend it changed at 1/2 the normal service intervals.
The Castrol VMX sounds good if it is for "hard to shift boxes". How long is the service interval?
How can you tell if it needs changing...colour? smell? Please don't say taste! haha
I've used VMX many of times on AWD boxes and it works really well. I will also be using it on my hybrid box. Normal service intervals in the Subaru book are every 100,000kms (Interval 4) but I prefer to do them every 50,000kms. It doesn't say on the VMX bottle that it suits "hard to shift boxes" but I find it does help immensley.nachaluva wrote:Oh, now I get it lol
Taste test is the way us John Wayne mechanics do it but for those that aren't so tuff.. smell and feel is the go. But you will need to know what you're looking for. Also when you drain it, you're checking for metal bits.
This is a typical subaru gearbox trait. Ruby Scoo does it and so does my mate's liberty.nachaluva wrote:I have had big problems with it crunching gears & when its cold sometimes it refuses to go into 2nd. Even when hot it wont go into 1st unless completely stationary.
1st I think had been designed to be difficult to engage when the car is still moving, to get around this double the clutch with a bump on the throttle to rev match - it's how I get around this one.
As for the cold second gearchange two things I've tried: one is to put in neutral with the clutch pedal out for 10 to 15 seconds before you head off, the longer you can do this the better. The other way to get around it is to drive in a way that you skip second gear - but without flogging the cold engine.
If you really do have chipped teeth it will sound like a very "organised" CV click - it will increase and decrease with the engine revs and vehicle speed, but ONLY in the gear with the chipped tooth - it is very audible. It will lead to the destruction of that gear and possibly the gearbox.taza wrote:my 1st gear which is pretty stuffed (teeth chipped).
If it crunches when you try to put it in that gear you have a synchro that's dying or is dead. Forcing it won't help, rev match-double clutching might help though.
Nachaluva, as for the oil, I'm using an LSD oil from my local parts joint, I can't remember the brand or any of that. The reason I've gone with this oil is because after a discussion with the fellas they recommended the oil due to the high temp stress that can be induced while 4wd'n. I've found shifting to be easier in general.
50,000kms isnt bad.RSR 555 wrote:I've used VMX many of times on AWD boxes and it works really well. I will also be using it on my hybrid box. Normal service intervals in the Subaru book are every 100,000kms (Interval 4) but I prefer to do them every 50,000kms. It doesn't say on the VMX bottle that it suits "hard to shift boxes" but I find it does help immensley.
How did I know you were gonna say taste haha
Yep I will look for metal bits. I'm sure there will be some as I've ground the gears a few times
Yep, I blip the throttle now before changing down into 1st or 2nd.El_Freddo wrote:This is a typical subaru gearbox trait. Ruby Scoo does it and so does my mate's liberty.
I dont really wanna have a car where I have to skip a gear lol. I've never owned a car like that & I dont want to start now. I'd prefer to fix it.
Any chance you can find the brand of the oil you use?
After much discussion & research, I've settled on Penrite SIN GEAR 75
Its fully synthetic, 75W90 API GL5/6. A little expensive, 2x 2.5L containers cost $110, but I wont have to do it again for a while & it should help my gear changes
Now I just have to wait for some nice weather to get under the car lol
Hope it helps mate, mines heaps nicer to drive with the stuff innachaluva wrote:After much discussion & research, I've settled on Penrite SIN GEAR 75
So today I did my 1st gearbox oil change
Took a bit of effort to get the nut off, magnet had some filings but I dont think too bad (comments?):
Then cleaned. Note the magnet in the middle (very nice touch Mr.Fuji):
I had just put through 2 cans of SUEC so the air filter assembly was already off giving me easy access to the filler/dipstick. I put in about 4L., reassembled everything & went for a spin around the block.
There is some improvement but not as much as I had been hoping for. I'll know more when I have a decent drive, esp when its cold.
I can now report it has made a difference
Did some nice tracks yesterday. As usual with my asthmatic EJ20J Foz, I need to be in exactly the right gear or she runs out of puff, which means downchanging into 1st on the move.
before, this meant jamming it in there, even with revmatching & double clutching. Now, i still double clutch but it goes in way more easily
Cold changes are better too, but its slotting it into 1st that is a big winner
:mrgreen::mrgreen:
Mine still doesn't go in 1st very wellnachaluva wrote:I can now report it has made a difference
Cold changes are better too, but its slotting it into 1st that is a big winner:mrgreen::mrgreen:
I know what you mean about running out of puff, thats probably my biggest issue with the engine in the foz. Maybe you should supercharge yours too. lol
We can cover Aus in supercharged EJ's..
Do you "double clutch"?taza wrote:Mine still doesn't go in 1st very well
They could breedI know what you mean about running out of puff, thats probably my biggest issue with the engine in the foz. Maybe you should supercharge yours too. lol
Seriously, if you do it well with no issues I'm absolutely positive I'm not the only who would be looking at doing it
